Wiring Q- kettle ov...
[Closed] Wiring Q- kettle overlaoding socket.
Any elec gurus about.
The socket in my kitchen started smoking yesterday, on further inspection the insulation on the live wire was burning.
It is a double socket spur onto the ring main with 2.5 mm2 cable. The spur is max 1-2 metres long.
Im at a loss to explain this, could it be that the kettle is knackered and drawing too much poewr? The toaster is on the same socket , which in retrospect is a bit daft but at the time of the incident only the kettle was on.
I am aware of part P regs, so of course this is a [cough] existing installation!
Posted : 24/01/2011 12:37 pm
Get a new kettle! Quickly!!
Spurs are not the best idea for heavy usage appliances.
Posted : 24/01/2011 12:53 pm
duff connection causing arcing / high resistance?
I'd suspect a slightly loose connection in the socket.
Posted : 24/01/2011 12:57 pm
Is it one of those no-cable kettles that drops onto the connection?
Posted : 24/01/2011 1:02 pm
Loose connection or terminal screw clamping onto insulation rather than copper resulting in arcing.
If that does not solve the problem get someone in to run a Z_e test on that ring and spur.
Posted : 24/01/2011 1:07 pm
cheers guys. I suspect it is the duff connection.
It is a wife-free kettle - would this have an impact?
Posted : 24/01/2011 2:16 pm
[i]wife-free kettle[/i]
It is awful when you have to make your own cuppa...
Posted : 24/01/2011 2:26 pm
lol wwaswas - you know what i mean, besides Im not married!
Posted : 24/01/2011 2:31 pm
lol wwaswas - you know what i mean (wire free - aka cable free)
Posted : 24/01/2011 2:32 pm
 5lab
yeah just sounds like the socket might have a slight short somewhere. I'd bung a new one on and see how it does
Posted : 24/01/2011 2:58 pm
