Wireless Router sud...
[Closed] Wireless Router suddenly started dropping out every few minutes
10 Users
I have a BT homehub which has worked fine for the last two years. For the last two weeks though it keeps disconnecting for a few seconds, flashing all it-s lights and then working again. Each time it does this my laptop gets disconnected from broadband and drops the VPN into work etc.
Is this likely to be the white home hub box or something else?
Do I just contact BT and wait for them to sort it out or is there something better I can do?
Posted : 16/10/2009 9:49 am
They should replace it but I would buy a decent router like a Netgear DG834.
Posted : 16/10/2009 9:51 am
I'm having a similar problem with mine, but oddly enough, it's not affecting my laptop, just my BT On vision system. Think I'm going back to Sky...
Okay, so if I got for the NetGear hub. Is there any real benefit in getting the more expensive ones? I run a wired in PC and a couple of wireless laptops. I only need them to connect around the house and not up/downloading massive volumes.
Cheap is good as long as it works.
Posted : 16/10/2009 10:04 am
I've got a dg834gt going spare wca - £25 posted?
Posted : 16/10/2009 10:06 am
I've had that netgear one for years - never had any trouble with it and I get reception everywhere in a 4 storey house.
Posted : 16/10/2009 10:07 am
wwwas - I really need it today. I have to get some stuff done for a customer which is why I have to be on the VPN which is why this has become an issue. Thanks for the offer but looks like I am popping down Argos.
Posted : 16/10/2009 10:10 am
ah, ok well no worries.
Posted : 16/10/2009 10:11 am
Are you sure it's not switching channels to avoid a neighbours wireless?
Sounds like it.
Posted : 16/10/2009 10:16 am
 DM52
does the wired pc loose connection when this happens? Could be a fault with the line and not the homehub, might be worth a call to BT to see if they have any drop outs registering on their logs before splashing the cash.
Posted : 16/10/2009 10:26 am
Try what BlingBling said, one of your neighbours might have a new router that's interfering with yours. If not, is there a firmware update or anything you could do?
Posted : 16/10/2009 10:32 am
Have a check to see if a neighbour isn't using a MIMO hub. These tend to flatten the output from non-MIMO ones on the same channel. Signs are high signal strength from a distant hub.
IME Netgear routers are sh1te.
http://www.singletrackworld.com/forum/topic/wifi-router-end-of-my-tether
Posted : 16/10/2009 10:38 am
Changed channel and it seems okay.
Posted : 16/10/2009 6:28 pm
