Any recommendations for a Wireless Range Extender?
Just looking at the Belkin G Wireless Range Extender/Access Point, any others ?
Is it within the same building (i.e. ring main)? Could you use Powerline Ethernet instead? I used a Linksys Powerline kit in a home install and it worked fine.
If you need to extend wifi to a particular place (garden shed?) then Pringles tubes work well I'm told...(no, really) ๐
tried a couple and ended up with the ring main ethernet option - which works well with a fixed station
The Develo Wireless Range Extender works well - gives you WiFi at the "remote" end of the Powerline link.
http://www.devolo.com/consumer/9_dlan-wireless-extender_starter-kit_product-presentation_1.html?l=en
I've had no problems using the Belkin as a bridge and a range extender.
I got it to replace owerline Ethernet adapters once we found out they were interfering with our neighbour's short wave radio.
