Windows 7
[Closed] Windows 7
9 Users
Does anyone know where can I get a full boxed version of windows 7 Pro 64 bit? It must be the full boxed retail version (not OEM) as I need it for Bootcamp.
Thanks
Posted : 03/03/2015 9:25 am
Can you buy a version of Windows 8.1 Pro retail and exercise your rights to downgrade. Microsoft should provide you with the key and the software.
Posted : 03/03/2015 10:23 am
Good luck, found lots of dodgy sellers and then luckily found a copy in my LCS.
Is there a reason you can't use the OEM version? It installs the same so long as it's the MS version not the manufacturer bodged version (Dell etc) it's just licensed to one install only once activated.
Posted : 04/03/2015 5:59 am
You can use the OEM version. I use Win 7 Pro 64-bit from a Dell disc on Bootcamp and Parallels on my iMac and MBP.
Posted : 04/03/2015 8:27 am
I believe the OP may want the retail version due to licensing issues?
I don't think it's for sale any more, if you (or someone you know) has Dreamspark Premium access (available to STEM students and teachers) then you can get a copy from there otherwise you're limited to tracking down a copy.
Posted : 04/03/2015 10:31 am
I haven't seen any full packaged Win7 packs in the channel for ages - eBuyer have low-cost packaged Win7Pro but it's OEM (non-branded).
What's your reasoning for non-OEM?
I don't know what bootcamp is.
Posted : 04/03/2015 10:36 am
Macs have a built-in system called Bootcamp which makes it possible to partition the main drive and run a Windows OS.
It appears from the OP that they're of the belief that Bootcamp won't work if an OEM ISO is used, which is not the case.
Posted : 04/03/2015 2:16 pm
[quote=Daffy ]Can you buy a version of Windows 8.1 Pro retail and exercise your rights to downgrade. Microsoft should provide you with the key and the software.
This - you can download the Win7 installation media (it's freely available on one of the MS servers).
Posted : 04/03/2015 2:24 pm
OP never said that.
As I said, it could be down to licensing issues.
Posted : 04/03/2015 2:46 pm
Cool your boots. I said that it [i]appeared[/i] that it was a OEM/Bootcamp compatibility issue, not that it was a certainty. What would the licensing issue be, other than that the OEM is meant as a pre-installed OS?
Posted : 04/03/2015 6:20 pm
OEM will be fine but you are on your own for support if it all goes wrong. Microsoft will expect the installer of the OEM to put it right. This might be a problem in a professional scenario. There is also a hooky way of using an upgrade disc to install the full version but I couldn't recommend this.
A downgrade for 8.1 is probably your best hope OP if you need support in future.
Posted : 04/03/2015 9:42 pm
Not hooky, removing ei.cfg is totally legit as you still need a valid licence key for whichever version you choose.
OEM is meant to be pre-installed. There you go. Not trying to be funny here but that can make a difference from certain perspectives especially where businesses and licenses are concerned. Plus the support issue.
Posted : 04/03/2015 9:49 pm
Three Fish - meant to say I wasn't having a go either 🙂
Posted : 04/03/2015 11:03 pm
