Windows 10 audio ou...
[Closed] Windows 10 audio outputs - stick / moon?
6 Users
Evenin' all.
Can I:
Listen to Spotify via my Fiio USB DAC and hphones and... also quickly swap hphones for my Jabra headset when a Teams call comes through?
Posted : 08/11/2020 5:32 pm
Yes. But occasionally it will forget your settings and same setup may not seem to work and it will extremely frustrating. With laptops and docks this happens more often.
Leave the Teams headset plugged in if it is USB.
Posted : 08/11/2020 5:54 pm
You can set the audio output for spotify in the audio settings of windows.
Posted : 08/11/2020 5:59 pm
I have a simmliar issue - headset with built in mic via USB for meetings, speakers plugged in via 3.5mm? standard audio jack. Via a laptop.
I find it's easier to just unplug one or the other depending on what I'm doing.
Posted : 08/11/2020 6:13 pm
I have music on Spotify going to the Bluetooth speaker. USB headphones for teams. It works fine.
Posted : 08/11/2020 7:56 pm
you just select the headset from device settings in Teams. Select the Spotify output from the task bar
It might need a couple more clicks to share system audio
Posted : 08/11/2020 9:46 pm
