Window putty....
[Closed] Window putty....
I've stripped the old paint off my sash windows, which are many moons old, and some of the old putty has crumbled off. Can i simply replace the bits along each pane that has come away or do i need to remove the whole strip and replace?
Posted : 08/09/2017 8:56 am
Yes you can fill in bits. The main advantage of replacing the lot is if there are draughts or passing traffic makes the glass rattle.
Posted : 08/09/2017 9:01 am
As above, easy enough to fill in if the remaining bits are solid.
I really like the smell of window putty ๐Ÿ˜‰
Posted : 08/09/2017 9:07 am
You'll have lovely soft hands after. ๐Ÿ™‚
Posted : 08/09/2017 9:12 am
+ 1
And who, as a kid, would drive your dad mad by pushing your fingers into the fresh putty he had just spent a weekend labouring over?
๐Ÿ™‚
Posted : 08/09/2017 9:51 am
just out of curiosity how long does this job take to do? roughly.
Got an old window at home that needs doing and ive never done it before.
Posted : 08/09/2017 10:13 am
Replace with Baby Bel wax.
Plus you get free cheese!
Posted : 08/09/2017 10:28 am
Can take hours / days depending on the window type and how diligent you are. Stripping a sash window, taking out the sashes and completely removing all paint and then repainting is a full WE job per window. With paint drying / base and then gloss coat, maybe two weekends all in.
Posted : 08/09/2017 10:42 am
<thread hijack>
I need to renew the the "putty" that sits between the wooden window frames and the stonework. It's a sort of murky red colour and quite a coarse texture. What the heck is it?
</thread hijack>
Posted : 08/09/2017 12:27 pm
Old Baby Bel wax from the 1930's.
Posted : 08/09/2017 12:40 pm
actually im doing what cougar is alluding to
Posted : 08/09/2017 12:41 pm
Burnt Sand Mastic originally or Polysulphide Trowel Mastic if more recent.
Posted : 08/09/2017 12:42 pm
oafishb beat me to it! ๐Ÿ˜‰
Posted : 08/09/2017 12:43 pm
I turned a Victorian 4 wooden panel internal door into a semi glazed door. Removed the top two wooden infills, got glazing cut to fit and bedded myself.
It was a really easy, satisfying and pleasant DIY job. spent a weekend doing it just so - linseed putty is a joy to use.
Posted : 08/09/2017 1:00 pm
It's probably 1890s vintage.
Oh, and, thank you.
Posted : 08/09/2017 1:01 pm
Note linseed putty can take a while to go off and some birds can take a liking to it, so keep an eye on it.
Posted : 08/09/2017 5:34 pm
