why is thinly slice...
[Closed] why is thinly sliced cheese so much more tasty?
21 Users
Than a thicker slice of the same cheese?
Posted : 03/12/2014 10:22 pm
Squashed or unsquashed bread?
Surface area.
 ton
asda spreadable mature cheddar is gorgeous.
Posted : 03/12/2014 10:25 pm
Think QI did a piece on grated cheese saying the same. Finer grating, more surface area, more flavour.
Well, my experiment consists of:
1) thin slice (1-2mm) of cheese placed on the tongue, unchewed = mouth watering and tastebud tingling
Rise with water and wait a bit
2) thicker slice (4-5mm) of same chese placed on tongue, unchewed = cheesy taste but not the tastebud tingling and mouth watering result.
Is it something to do with meltingness?
Posted : 03/12/2014 10:26 pm
Lots of stuff is like that eg.carpaccio or tomatoes. I put it down to having more air around what you are eating but that's only my guess
Posted : 03/12/2014 10:27 pm
NW: I wouldn't sully the taste with [i]bread[/i] of any sort.
Posted : 03/12/2014 10:28 pm
Nice Granny Smith apple maybe.
sliced thinly
Posted : 03/12/2014 10:30 pm
and for super tasty, it needs to be sliced by and eaten off a penknife too.
Its voodoo I tells yah.
Depends on the cheese as well. A sock meltingly strong cheddar with those crystal bit in it that makes your mouth pucker up on tasting can only be consumed in lumps. Thinly slicing would turn it into crumbs
Posted : 03/12/2014 10:33 pm
How do you slice Brie 1-2mm thick? As long as there is plenty of room for thick bacon and cranberry between the bread as well, I don't care. I would be perfectly content to never eat anything else again apart from that.
Posted : 03/12/2014 10:35 pm
you dont. You wipe the slab of brie across the biccy until it's slathered.
Posted : 03/12/2014 10:37 pm
Stoner +1
If you can slice brie it aint ripe.
Posted : 03/12/2014 10:40 pm
Ah, I feel I must try this new technique IMMEDIATELY.
Northwind - Member
Others do this too? 🙂
Posted : 03/12/2014 11:30 pm
Northwind - Member
[i]Squashed or unsquashed bread?[/i]
Others do this too?
Other freaks you mean? 😉
I remember the QI where they said it's to do with vol vs surface area. I'm no connoisseur, but I guess it's similar to the sucking air through your teeth into wine for maximum flavour.
Room temperature food and drink also has the most flavour.
Apple's are best when they're sliced and about to have crumble or pastry put on top of them.
Posted : 04/12/2014 3:36 am
+1 for stoners serving suggestion - cheese n Apple n penknife in the shoffice.
Posted : 04/12/2014 8:05 am
ton - Member
something won't let me believe you....
tastes even better grated.
Posted : 04/12/2014 8:14 am
I find grated cheddar tastes even better than thinly sliced. I also put this down to surface area. However, even after it is moulded back into an amorphous solid shape it still tastes better than the same size piece chopped off in one lump. I reckon that there is some pesky science involved.
Posted : 04/12/2014 8:19 am
Maybe it builds up a layer of oxide - which is why it's so much better when it has 'warmed up' a bit? The bacteria may get busy when exposed to air or something.
I wonder if you could anodise it - by extension that should make even rubbish cheese taste amazing!
Posted : 04/12/2014 8:22 am
I guess grating would warm it up a bit too. I like the oxide theory as well. Where's Heston with the answers when you need it.
Mmmmm, purple cheddar
Posted : 04/12/2014 8:31 am
Warming up (i.e. room temp or above) cheese helps release the esters within the cheese, thus more flavour.
The same reason proper beer tastes better at 10 deg than chilled and chilled lager tastes better than if its warmer (because its crap). Try Newcastle Brown ale if its been allowed to warm up a bit, its foul!
Posted : 04/12/2014 9:50 am
The only way to drink Brown Ale is off the shelf! What's all this chilling about?
Posted : 04/12/2014 12:00 pm
Anytime I've bought a bottle of nukey brown its been chilled to near freezing point. I wouldn't choose to drink it unless there was no alternative. Horrible horrible beer.
Posted : 04/12/2014 12:15 pm
Yanks serve porters, stouts, IPA, etc, ice chilled. Just wrong. It's like Guinness Extra Cold. WTF! (though I suppose that comes under the, it's crap anyway so what the hell).
Posted : 04/12/2014 4:14 pm
All cheese, no matter how nice, also tastes better when melted! FACT!
Whether its teeth-waveringly strong cheddar, onto toast with Worcester sauce. Or Camembert, shoved in the oven until volcanically hot, then having crusty bread dipped in it. A cheese single melted onto a fish finger butty, or stilton with ham in a hot oatcake
See... incontrovertible!
Posted : 04/12/2014 4:21 pm
why are [i]you[/i] so much more tasty?
Posted : 04/12/2014 4:43 pm
 wors
Mature cheddar sliced wafer thin, now that is lovely.
Posted : 04/12/2014 4:48 pm
piedi di formaggio - Member
Git! I'm sat here, eating a plate of cold roast chicken and chips, and you've got me wanting to hunt down a chunk of weapons-grade Cheddar! 😉
Posted : 04/12/2014 7:55 pm
