Where can I buy som...
[Closed] Where can I buy some 12mm o/d plastic tube/sleeving/pipe?
9 Users
I'm looking for some plastic/nylon etc tube/sleeving/pipe with an o/d of 12mm. Ideally with an i/d of 8mm or 10mm (pushing it I know).
I only need a couple of 200mm lengths, it's for a home brew bike stand for a RF Cinch crank as I'm struggling to find anything.
I can do all the metal snotting, I just need something friendly to slide into the crank.
Cheers.
Posted : 05/01/2017 8:33 pm
[url= http://www.ebay.co.uk/itm/Cold-Pressed-Steel-Tube-Various-Sizes-Available-/161866045698?var=460836361047&hash=item25aff7d902:m:m14tLN-gyS5VVqn93TM3aFQ ]fleabay[/url] oops need to improve my reading skills 🙂
Posted : 05/01/2017 8:37 pm
Thanks, but I should have said I'm looking for rigid stuff.
Posted : 05/01/2017 8:42 pm
I could sort you some stainless tubes, the bore is definitely 10mm, pretty sure the wall is 1mm.
How many do you need ?
A 12mm plastic pipe will be pretty bendy.
Posted : 05/01/2017 8:48 pm
Thanks for the kind offer kakisawa, much appreciated, but ideally I'm looking for something nylon/plastic so it's not metal on metal. It's to act as a sleeve on a crank type stand.
Posted : 06/01/2017 10:42 pm
[s] http://uk.rs-online.com/web/p/plastic-tubes/4084018/ [/s] DOH!
Posted : 06/01/2017 11:46 pm
Shrink sleeves? If all you want is some protection on a metal arm.
Posted : 07/01/2017 7:08 am
 Bear
I've got some 12mm Uponor pipe which is a composite pipe of plastic and aluminium. Not sure of internal dims though.
Google Unipipe to have a look and get back to me if you want some I could cut you a few bits.
timATj-twren.eclipse.co.uk
Posted : 07/01/2017 8:47 am
[url= https://www.theplasticshop.co.uk/ptfe-tube-10-12-14-15-16-18-20-22-25-30-35-40-45-mm-od.html ]Is this what you want?[/url]
Posted : 07/01/2017 10:24 am
If its only for protection wouldn't hosepipe do ?
Posted : 07/01/2017 10:28 am
