Whats this warning ...
[Closed] Whats this warning light on our Berlingo dash?
2005, 2.0 HDI. Far right of dash. Intermittently shows, more not lit than lit.
[img][url= https://c5.staticflickr.com/6/5510/30074596284_b03b71c6dd_z.jp g" target="_blank">https://c5.staticflickr.com/6/5510/30074596284_b03b71c6dd_z.jp g"/> [/img][/url][url= https://flic.kr/p/MPAaG9 ]2016-11-01_08-18-59[/url] by [url= https://www.flickr.com/photos/martinddd/ ]martinddd[/url], on Flickr[/img]
[img][url= https://c5.staticflickr.com/6/5704/30074634804_81d7544eab_m.jp g" target="_blank">https://c5.staticflickr.com/6/5704/30074634804_81d7544eab_m.jp g"/> [/img][/url][url= https://flic.kr/p/MPAn9h ]2016-11-01_08-21-13[/url] by [url= https://www.flickr.com/photos/martinddd/ ]martinddd[/url], on Flickr[/img]
Ta.
Posted : 01/11/2016 9:26 am
Any of these?
[img] ?utm_source=DesignTAXI&utm_medium=DesignTAXI&utm_term=DesignTAXI&utm_content=DesignTAXI&utm_campaign=DesignTAXI[/img]
Posted : 01/11/2016 9:29 am
I think it means user manual in glove box 😆
Caution, land mines.
It's Fajita Night!
Posted : 01/11/2016 9:30 am
Coolant level or brake oil level?
Posted : 01/11/2016 9:31 am
Critical level of dust build up.
Decomposing pumpkin is now floating in river?
Low coolant.....check the radiator expansion tank (when engine is cold)
A guess but ....
Check coolant level? Looks a bit like an expansion header tank.
But you should check with the Spanish bloke in the glove box.
His name is Manuel.
Posted : 01/11/2016 9:32 am
Coolant level low. Heed the big red "STOP" warning and switch the engine off.
Posted : 01/11/2016 9:33 am
Coolant it is. Many thanks.
Posted : 01/11/2016 9:36 am
TBH, if it's intermittent its quite possibly a faulty sensor. Or just slightly too low rather than half empty.
Posted : 01/11/2016 9:37 am
 bbb
As mentioned before it is the low coolant level light. Check coolant level when the engine is cold and top up. Failure of this sensor is common after 10 or so years. You can replace it or just unplug it.
If the coolant level is ok then it is the coolant level sensor - easy to replace. Unclip the connector and twist and it can be removed from the expansion tank. Refitting a new one is the reverse process.
http://www.ebay.co.uk/itm/OVERFLOW-EXPANSION-RADIATOR-COOLANT-FLUID-LEVEL-SENSOR-1-4-1-6-1-8-1-9-2-0-2-2-/252355644892?fits=Model%3ABerlingo&hash=item3ac1918ddc:g:XccAAOSwiYFXD5jr
Posted : 01/11/2016 9:39 am
It's a Berlingo with 93k - probably an electrical fault.
TheGingerOne - Member
You have been listening to Craig Brown on the iPlayer and I claim my £5.
Posted : 01/11/2016 10:24 am
Coolant. Peugeot Expert here. 2L hdi. 147k on the clock. 47 of those with that thing on and off... If the temp drops to nothing I'll worry!
Posted : 01/11/2016 10:29 am
Is it the Rasta Hat sensor?
Posted : 01/11/2016 10:33 am
It's the "get the frack out the middle lane" lamp, or GTFOTMLL as it's known.
In most Berlingo's it's illuminated pretty much all the time..... 😉
Posted : 01/11/2016 11:39 am
Coolant level, the sensors can get shited up and give a false low reading, it's a black rectangle box on the header tank, bayonet fitting, quarter turn out and clean the prongs with a paper towel
Posted : 01/11/2016 12:07 pm
Same on the pug Expert too...
Posted : 01/11/2016 12:08 pm
