What tool do I need
[Closed] What tool do I need
 iolo
[url= http://farm6.staticflickr.com/5530/9963175783_11c9c23dac.jp g" target="_blank">http://farm6.staticflickr.com/5530/9963175783_11c9c23dac.jp g"/> [/img][/url]
to take this shade off? The bulb's blown.
Have you got any links as to where to get one?
Thanks in advance
Posted : 27/09/2013 10:00 am
Hammer.
B&Q.
HTH
Posted : 27/09/2013 10:02 am
 iolo
That's one option but I would like to be able to reuse it if possible ๐Ÿ˜€
Posted : 27/09/2013 10:08 am
It looks like some sort of security bolt, I'd get out the needle nose molgrips...unlikely to be that tight bearing in mind it's tightening onto glass.
Posted : 27/09/2013 10:14 am
Drill/Dremel the sucker out then put a normal fixing back in.
Posted : 27/09/2013 10:16 am
dremel a flat on it.
use screw driver.
Duct tape.
I know, problem solving is a real passion of mine.
Posted : 27/09/2013 10:17 am
I'd imagine some kind of [url= http://www.amazon.co.uk/PIECES-SECURITY-TORX-SCREWDRIVERS-BITS/dp/B002QPHK3C ]security torx tool[/url] (not sure exactly what kind though, those in the bottom left look likely-ish)
Posted : 27/09/2013 10:20 am
You can do it with patience and a flat head screw driver as long as it's not too tight, failing that, pliers, molgrips or similar.
Posted : 27/09/2013 10:21 am
I would also use myself or pliers. And replace with a normal bolt.
Posted : 27/09/2013 10:25 am
