what the hell is th...
[Closed] what the hell is the problem with my laptop
6 Users
(Vista Home/4gb of RAM/AMD64) keep getting a message saying my C drive is nearly full, I check the computer and low and behold the drive is nearly full - big red line and all that
doesn't matter how many times i remove some program the line or amounts of gigs used doesn't go down (in fact a couple of times it went up)
Using Revo Uninstaller and "yes" I am refreshing the computer details 🙄 I'm dumb but not that dumb
Posted : 04/07/2009 10:05 pm
have you got some back up software, that is inadvertently backing up to the c: drive and filling itself up?
i have experienced this on some IBM laptops that come pre-installed with Rescue and recovery software.
have a look on the web for a piece of software called Spacemeonger - it gives you a graphical representation of what is using up the space
Posted : 04/07/2009 10:32 pm
don't forget to clear out the recycle bin?
Posted : 04/07/2009 10:43 pm
ithasnotgotwheels
Posted : 04/07/2009 10:46 pm
Vista is particularly vicious in setting system restore points. Delete all but the last one, you will be surprised by how much disk space you recover, especially if your installation is mature!
Posted : 04/07/2009 11:02 pm
You can right click each directory and determine where the space is being used but as Trampus says, the restore points that vista uses are quite bizarre and grab masses of space. You'll find them soon enough by right clicking and selecting properties for each root folder and then working your way down from there.
Posted : 05/07/2009 12:04 am
