What present day ca...
[Closed] What present day car will be a solid and reliable car in 10-15 years time?
I find it interesting that emissions regulations get the blame for the increasing complexity of cars, which these days "have" to have:
- Climate control
- Power steering
- Satnav
- Heated & electronically controlled seats.
- Electric windows/mirrors
etc.
Posted : 18/11/2015 12:43 pm
Don't most main dealers now avoid retailing anything over 5-7yrs+. Not exactly encouraging is it.
Or there just isn't a margin in older cars.
Look in glasses/parkers and the difference in PX to dealer price is 20% of the value. That's on a £100 on a £500 banger or £2k on a £10k nearly new Focus. Seeing as (cashflow aside, lets assume they're managed well and can deal with that) they're limited by space, so if cars take a weekend or two to sell, that space on the forecourt can either net you £100 or £2k, which car would you put on it? That's why they send PX's to the auctions, they could lose the whole £500 and still be better off selling another car with a £2k margin than tying up that space.
That and there's always an abundance of 3 year old lease cars to sell which fits in with most peoples mentality of buy a 3yr old car once the depreciation has waned, so they're quick and easy to shift.
Posted : 18/11/2015 1:08 pm
Whilst it's true that an AC compressor is an expensive item should it break, my car doesn't need an oil change every 5,000 miles, valve clearances resetting, fuel mixture setting, points, etc, etc.
Yes but that is all simple driveway servicing your everyday owner could do It's not non serviceable items failing requiring expensive expensive replacements.
The modern car has killed the home mechanic.
Posted : 18/11/2015 1:44 pm
Don't get so hung up about a car lasting 10 years. You could drive it out of the showroom and written off within minutes (mate got pranged when he was waiting to turn into a petrol station to fill up for the first time...).
Posted : 18/11/2015 2:23 pm
[quote="philjunior"]
- Climate control
- Power steering
- Satnav
- Electric windows/mirrorsFailed emissions equipment can stop the car, or destroy the engine, or make it an economic write off, broken sat nav can't......
Posted : 18/11/2015 3:57 pm
[quote="MintyJim"]Bloody Touran has died again, fault code is stating P0321 which is the crank speed sensor implausible speed - which I replaced 300 miles ago. Gutted as it's actually a really good car. I'd be checking the connector for corrosion, tracking the harness round the engine bay looking for chafe damage (it's not hugely uncommon to find bits of harness resting against edges of body structure/powertrain after a few years use) so you might get a short of some description, then have a poke around inside the bell housing of the gearbox, see if the sensor ring is damaged, dirty, corroded. I've seen what happens when (for instance) the starter motor doesn't sit quite straight, it eats the ring gear and sprays metal filings all over the inside of the bell housing and clogs everything up, including the sensor ring (and sensor). A stone can damage it (depending what sort of ring it is, and if the housing is open anywhere) so the sensor can't see it anymore (gap is too big) or a feature is damaged so the sensor gets an illogical number of pulses. Could also be that the sensor is slightly out of position, that'll give you some odd signals as well.
Posted : 18/11/2015 4:03 pm
Thanks Ghostlymachine, interesting comments. I plan to check the loom and I'll also be changing the starter motor which could be forcing issues as it struggles to start from cold - battery is fine.
It's a DSG if that makes any difference??
I've also put the Honda on hold for now and have decided to throw a little more time and money at the Touran so my car of future could change.
Love the idea of the Landy, I grew up with them and living on the coast in West Wales they're 2 a penny plus everyone, including me, can fix them!
Posted : 18/11/2015 4:51 pm
I've got a Defender, and recently I've been taking a curious interest in other cars. The Jazz Si was one I liked the look of. However, I visited a Honda showroom and had a look at the new Jazz (mid-level model) and a Civic Tourer, and like someone else mentioned, I wasn't too keen on the trim. I know Hondas are reputedly very reliable, but they seemed quite flimsy, and I'm not sure how the non-mechanical parts would stand up to high mileages over many years.
As for the Defender, the main problem is probably 'the rot'. Not only the chassis, but the aluminium/steel interfaces. Mine is actually not too bad - it usually gets an annual under-body treatment, but some parts of the bodywork are blistering. It had two new doors just inside the 6 year warranty. It's had a few breakdowns and problems, but most of these tend to be cyclical - ie the same things go every few ten thousand miles. Overall, it's not bad for its age and mileage, and I'm fortunate in having a good specialist close by who's seen all the problems before. Also, parts are readily available and generally not too expensive.
On the other hand, I've heard a good few horror stories about some Discovery and Range Rover models - I'm not sure many of these will be around in 15 years, as they can eat up a lot of money.
Posted : 18/11/2015 5:36 pm
You're right - modern cars are so much better.
Incorrect.
There's no reason why they can't be though.
As is the modern way things don't last because they are designed not to. There's no money to be made if things last forever.
Whats your basis for cars not being designed to last. The first few cars and vans I bought in the late 80s / early 90s had 5-digit odometers. By 1980s/90s standards my last van had been round the clock three and half times before I sold it and apart from consumables and service items had an all original drive train and it was all still going strong. I typically don't buy vehicles until they've been two times round the clock and I'm confident they'll each last me 5 - 8 years and at least another 100k.
My typical experience in the late 80s / early 90s was clutches lasting 30k, gearbox failures between 60k and 80k, fuel tanks rotting through at 80-90k, then structural rot and an MOT failure sheet 2 pages long by the time it was approaching 10 years old whatever the milage.
The issue isn't the quality of manufacture its the complexity of manufacture to achieve the efficiency and performance we want these days. My current bog standard, 10 year old astra van is quieter, more powerful, has double the mechanical longevity and unmeasureably better integrity and build quality, is safer, requires less frequent servicing, is more reliable and uses between a third and a half less fuel of the one I used to drive 20 years ago. Its also older (at the point of purchase and use) and was cheaper to buy than the one I had 20 years ago too.
The issue of complexity isn't that the car is designed to fail its that there are too many mechanics who aren't competent at maintaining and repairing them, believe that modern components can't be repaired and can only be replaced and most importantly have no idea how to diagnose them.
Posted : 18/11/2015 6:15 pm
 hora
Theres no margin in cars 5-7yrs+? Poppicot! Ever see the difference in what your offered at trade in and the dealers asking price for the car that you are buying? Does your px go to a Nun run orphanage as a gift? Does wbac run with excellent offered prices?.. 🙂
I'm saying main dealers seem to be avoiding retailing such cars. Why?
Posted : 18/11/2015 7:11 pm
I once rebuilt an engine on a 1980s Citroen. The big end bearing shells were shot, the journals were showing ovality, the piston rings were worn and the tappets were knackered.
This was on a car that had done 75k. Now, you could argue that it was repairable by a home mechanic, but I'd rather have a car that didn't require Sundays spent fixing the damned thing, and the occasional large garage bill is a small price to pay for cars that just work.
Posted : 18/11/2015 8:44 pm
All this is an excellent case for buying a 1950s Raleigh Superbe roadster.
You can guarantee it will still be running in 50 years. 🙂
Posted : 18/11/2015 9:31 pm
[quote="hora"]I'm saying main dealers seem to be avoiding retailing such cars. Why?There's no margin on them. The difference between trade in and sale values has to cover wages, tidying it up, possibly a service, space to store it, advertising it and the discount they give you off the new car.
Plus they get no volume discount from their importer.
Posted : 18/11/2015 9:33 pm
So, has anyone proposed a 2015 model car yet?
Posted : 18/11/2015 10:09 pm
I thought this was due to the number of people willing to seek legal action for faulty goods these days. I don't think that is anything to do with declining reliability of cars though. More due to the increasing amount people suing people in general. Not really worth it for a couple of hundred quid.
Posted : 18/11/2015 10:39 pm
My old Corsa 1.8 with 109,000 miles on the clock was going very strong, unfortunately met it's fate in the hands of a chav and quickly joined the scrapheap.
Therein lies the issue, the value of cars in this country is way too low for people to give a hoot about once they reach their old age. I seem to recall a lot of rusty/broken old cars of little value on drives as a child, with owners spending their free time doing them up. Hardly ever see such vehicles now.
My corsa actually made sense for a long-term bet. Simple mechanicals, cheap spares, rugged and an understressed engine with spares at any scrapyard nearby.
Posted : 18/11/2015 11:06 pm
2015 Dacia Sandero. No toys, superb access to engine, very little emmisions electronic trickery. Thousands of them in France less common in UK 'cos they've only recently started doing RHD versions.
The only problem will be finding one at 10 years old cos I reckon the uncool badge will mean many good ones getting scrapped before their time.
I think I'm first to suggest a 2015 model. What do I win?
Posted : 22/11/2015 12:50 pm
Go for the uncool car with no major bells and whistles then choose the simplest engine. That's what I did. A 63 plate Fabia, the only luxury is A/C. The 1.2 12v engine that's got no DMF, DPF (petrol) manual gearbox and no known major issues. Heading towards 30k now and it's just starting to loosen up!
Bought it to replace a 9 year old Fiesta 1.25 that had done 133k. Engine was still sound and the bodywork was rust-free but all the trim was falling off it, creaks galore and always needed a new pair of headlights (the bulb auto-adjust motors would fail, known issue) and at least one new front spring (snapped them for fun, another known issue) at each MOT. Was just incredibly annoying to drive and own so got shot of it.
I hope to get 10 years + out of the Fabia 🙂
Posted : 22/11/2015 1:42 pm
A modern car needs little more than a change the oil every year and the occasioanl new part itll keep you mobile indefinitely.
LOL.
Posted : 22/11/2015 2:25 pm
Hopefully, the one I bought on Friday in exchange for a sum of money and its unreliable predecessor.
Posted : 22/11/2015 3:53 pm
I drive a 96 Volvo 850SE 2.5ltr, had an intermittent fault, which often see's these head to the scrapyard as garages tend to claim its the ECU or similar and could cost a fortune to diagnose let alone fix.
After about 3 days of head scratching I managed to suss out that it was the Engine Temp Sensor and it cost me a whopping £20 for the sensor and a few quid to a mate to swap them over (I would have done it but the restaurant has me too busy).
Now thats fixed I anticipate only about another £100 spend on the horizon (replacement shock) and then it should be good for at least another 12 mths. (oh a small rusty patch on the drivers side wing)
All the spares are available for these things and thankfully they're from just before everything became overly computerised.
It's also very comfortable, safe and quick. Whats more once we capture those ISIS oil wells the cost of unleaded is bound to plummet!!
And its a saloon so it can't ever be considered "desirable"
Posted : 22/11/2015 6:52 pm
Page 3 / 3
