Looking for an option for a light to go on a corner so it will light up the front of the house (the drive) and the path to the door which is on the side.
Found this so far but it doesn't fill me with much excitement....
[img] http://s7g3.scene7.com/is/image/ae235?$p$&layer=0&size=281,281&layer=1&size=281,281&src=ae235/67936_P [/img]
EDIT - with a PIR
I would go for seperate 10 watt LED lights with 2 sensors linked together so that they both come on when one or other sensors triggered.
or if i was feeling lazy id just fit 2 of the ledhut 10 watt integrated sensors/leds - one to each side of the corner - plenty light where you need it and costs less than those halogen numbers to run. - ive fitted them front and back at my gaff , plenty bright enough for security and seeing when im getting firewood in. and then i mounted both my 250 watt halogens on the front of the garage on switches as worklights for working on my motors at night
for me that light you linked mounted on a corner will have a limited sensor pick up.
id even go as far as to suggest that ledhut have some solar LED lights which ive mounted where i CBA running cables to make sure no dark corners exist for pikeys to lurk round my garage window.... and they are taking a beating with regards to wind and weather - and holding up well and are plenty bright for lighting up a walkway - not so much a drive way mind you.
(i dont work for ledhut)
