What logs for a log...
What logs for a log burner?
31 Users
58 Reactions
Having never had or used one before I'll be using a wood burner and gas central heating to stay warm this winter.
The wood burner is a 5kw MrFires Firecracker in large, so accepts logs up to 300mm long and briquettes and was installed in February this year with a lined flue.
I'd like to think I'll use it in the evening when home from work for a few hours and at the weekends for longer. It's in a tiny, period, cottage so will hopefully heat the whole place through.
It seems the type of wood I burn is reminiscent of asking for what tyres to use on here!!!
Via Google I've settled on birch for easy burning,it's of heat & flames and found this supplier online:
https://www.uklogsdirect.co.uk/kiln-dried-logs-c1/kiln-dried-birch-logs-c4/kiln-dried-birch-logs-half-crate-p3
Anything else I need to consider, any recommendations of online timber suppliers, advice???
Ta
Posted : 09/09/2024 9:56 am
Birch burns nicely for us, but if we had central heating we'd use that rather than waste money on a stove and buying in logs...
Posted : 09/09/2024 10:00 am
SYZYGY, Del, SYZYGY and 1 people reacted
PS: is it a nonsense to buy kiln dried logs and store them outside in wood store?
It's in a rental property and may have the advantage of adding dry air to a house built into a hillside.
Posted : 09/09/2024 10:05 am
Whatever’s free.
Everything and anything. If it's properly dry and the flue draw is adequate it'll burn. Some stoves with "double combustion" burn stuff like pine better, Jotul for example. The trick is to burn fast and hot so you don't cack up the stove and flue and pollute more than necessary. Hard woods will burn in pretty much anything.
Posted : 09/09/2024 10:06 am
Del and Del reacted
For the few times a year I use ours I've switched over to heat logs. Cheaper, more consistent, bugger all ash produced.
Posted : 09/09/2024 10:12 am
 Yak
Properly seasoned dry ones from a local log supplier if buying now. If you have access to free wood, get it in now, cut, split and season for next year. Ash, birch, oak, most hardwoods are fine. Softwoods fine too mostly. Kiln dried seems pointless though. There must be a local supplier near you?
Posted : 09/09/2024 10:26 am
Whatever is dry, local and (if possible) free
Posted : 09/09/2024 10:43 am
Good advice from @Yak above. I would like barn dried or traditionally seasoned logs but they are very difficult to get round us now as the supplier can’t keep up with demand. Last two loads, which are 3cubic metres each have been oak, beech and a small amount of birch, kiln dried and £470 delivered. Price has stabilised now after a few years of constant rises but I’ve just finished a second log store to make sure I’ve got enough for winter. There is sometimes low availability round peak holiday home usage at Christmas/new year so don’t leave it too late to order, making a good relationship with your local supplier is a good idea too!
Posted : 09/09/2024 10:44 am
flicker and flicker reacted
Nothing heats a tiny period cottage. You merely stand in the way of the heat as it tries to escape.
Posted : 09/09/2024 10:51 am
robola, integra, TiRed and 7 people reacted
you'll need your head looking at if you buy those logs linked at 225 for a half crate.
Thats damn near petrol station forecourt prices.
i order mine from local tree surgeon in the summer.
he delivered last week - 3 cube - 2 cube soft 1 cube hard wood  for 290 dropped beside my log store
Posted : 09/09/2024 11:10 am
I've been using mostly sycamore and beech and they've been great.
Gathered in April/May and put in the woodshed until I start using it in about November they are plenty dry enough, I know people say a year but it seems to work for me. Still loads of storm damage round here to clean up after Arwen, and some more recent ones, so it's been down a while before I get to it, which helps.
Posted : 09/09/2024 11:33 am
My local woodyard is £185 for a cubic meter of loose seasoned hardwood, their prices go up from there. Probably reflects regional differences in price and that everyone has a wood burner around here.
Posted : 09/09/2024 11:38 am
have a look and see who's taking out all the die-back afflicted Ash in the area - it's one of the only species you can burn almost green as the moisture content is super low. Literally only a few weeks dry storage and it's good to go. It also burns ****in hot, and pretty clean. We had to have an ash taken out a few years ago and still got enough for 2 stoves this winter, and there's now another tree that needs to come out which is bigger than the last one, so will be good for a couple of years. I just have the tree surgeons rin the stick up and ive then got punishment splitting to do for a few months which helps me to feel a bit better about mysefl if I've been lazy!
Posted : 09/09/2024 11:58 am
My favourite is cherry as it smells amazing. Ash, beech and oak are great. Anything dry (below 20% internal moisture content) will burn. Get a moisture meter and check any wood deliveries you get BEFORE they unload. I’ve refused deliveries before as the sellers were trying to pull a fast one.
Posted : 09/09/2024 12:09 pm
dyna-ti and dyna-ti reacted
Controversial but bear with me.
B&Q bags of kiln dried hardwood c£25 each bag (coal sack size).  Proper kiln dried not the rubbish from garage forecourts.
we sometimes buy this for convenience or if run out. As bulk tonne bags of kiln dried hardwood from local supplier £200-£220 each the B &Q prices not too bad in comparison.
If can, plan ahead and buy cheaper and season yourself. But min 12 month seasoning time IMO.
Posted : 09/09/2024 1:05 pm
Free wood burns hotter. Science fact
Posted : 09/09/2024 3:06 pm
flicker, the-muffin-man, the-muffin-man and 1 people reacted
...and every heat-treated pallet that comes my way is soon grabbed!
I hate it when summer goes, but I do like the log-store management in the colder months. 🙂
Posted : 09/09/2024 3:19 pm
What's wrong with using the central heating?
Posted : 09/09/2024 3:25 pm
 mert
Most of them are sized for nominal insulation levels and nominal weather.
Posted : 09/09/2024 3:41 pm
Heating engineers tend to over size boilers and radiators, IME.
Posted : 09/09/2024 4:07 pm
ransos
What’s wrong with using the central heating?
Nothing, I will use it, most likely in the mornings. But, I have a wood burner, something I've never had before and I'd like to give it a try.
Plus, I live on my own and don't have a TV so staring at the flames whilst talking to my rubber tree will hopefully keep me sane through the long winter months.
Posted : 09/09/2024 4:36 pm
pacman404 and pacman404 reacted
Did you used to do surgery? On girls in the eigh-eeee-teees?
I found gravity always won.
Posted : 09/09/2024 4:52 pm
reeksy and reeksy reacted
 5lab
I've just had to chop up a 65' ash tree that fell down on Friday (co-incidentally the same day I did a chainsaw course). Ash doesn't need as much seasoning as other woods, and can be burned nearly straight off the tree (but burns a little better when its dried out properly).
Got to figure out how to split the damn stuff now - the lower section is ~50cm rounds and strong as owt.
if you're in sussex gimme a shout 🙂
Posted : 09/09/2024 4:57 pm
integra and integra reacted
Got to figure out how to split the damn stuff now – the lower section is ~50cm rounds and strong as owt.
Splitting axe/maul, and maybe a wedge or two - but at 50cm a splitting axe will eat it up as freshly felled without a wedge. Splitting axe very not the same as a felling axe btw ;o)
Posted : 09/09/2024 5:15 pm
You can always tell the ones on here with no log stove and would probably want one
I love watching the dancing flames as the tertiary air ignites any unburnt gases from the primary burn for a complete clean burn
Posted : 09/09/2024 5:22 pm
pisco and pisco reacted
 5lab
Splitting axe/maul, and maybe a wedge or two – but at 50cm a splitting axe will eat it up as freshly felled without a wedge. Splitting axe very not the same as a felling axe btw ;o)
I've had a go with our maul. It just bounces off the thing when I aim for the middle (it works fine on ~30 cm rounds). Watching a couple of vids it seems like I might have more luck starting from one edge and working in..
Posted : 09/09/2024 5:37 pm
What’s wrong with using the central heating?I
Is kerosene more or less  sustainable ?
Posted : 09/09/2024 5:41 pm
Exactly, and, similarly, despite all the bollocks talked about it, it doesn't really matter that much.
Posted : 09/09/2024 5:43 pm
 myti
@5lab I'm in Brighton and could do with a bit of Ash if you want to sell me some. My usual supplier of local barn dried has given up doing logs.
Posted : 09/09/2024 5:51 pm
Pauly, 5lab, 5lab and 1 people reacted
If the rounds are too thick, aim to start by splitting off bits round the edge rather than aiming right down the middle. Once a bit is taken off the outside it’s much easier. Watch for the maul bouncing off sideways though.
Posted : 09/09/2024 6:01 pm
reeksy, beagle, reeksy and 1 people reacted
With big rounds, I've found it better landing the splitting axe near the edge rather than smack in the middle. Can still be across the middle of the log, but going near the edge you're propagating a split in one direction, not from both sides of the axe head.
Wood grenade splitting wedge if that fails.
Knarly bit with branch unions - chainsaw as last resort.
Looking forward to stove season. I do enjoy the destressing time after work lighting the stove and flame watching.
Posted : 09/09/2024 6:43 pm
graham_e, reeksy, reeksy and 1 people reacted
As others have said, properly seasoned hardwood logs from a local supplier are best. Kiln dried is a waste of money and energy as the logs will gradually return to the moisture content of air dried if stored outside. There are differences in hardwoods (birch easy to get going, oak is a slow burn) but try not to overthink it. Anything seasoned will be fine. Softwood in small quantities in a log burner will also be fine.
I supply mixed hardwood logs so if you’re near Cardiff, give me a shout.
Posted : 09/09/2024 7:15 pm
beagle and beagle reacted
 5lab
@myti the logs are just the other side of the south down from you in Clayton. Happy to sell some but they won't be split (there are some smaller logs that don't need splitting tbh). Drop me a PM.
Ta to everyone else for the splitting tips - are grenade wedges worse in any way than "2 dimensional" wedges? I'm not super accurate with an axe, and thinking if I want to split along a line, I might get better results with a couple of wedges and a sledge.
Posted : 09/09/2024 7:50 pm
It's splitting wood not a fashion show. There's no need to "split along a line"
Grenades work fine. But I find if the maul doesn't work the grenade just gets planted.
7t log splitter rarely struggles though
Posted : 09/09/2024 8:07 pm
For the OP dry is the key thing, almost any species will burn well in a stove with good flue. Mix of softwood and hardwood is good as the softwood will get everything up to temperature quicker.
@5lab work the edges of big rings to make them like a 50p and then start breaking into the heartwood. Ash generally splits easy fresh or seasoned. Cut out any branch unions for an easy life and keep them to one side for long burns.
Posted : 09/09/2024 8:21 pm
Wood grenades are only good for blunting chains as you try and remove them.
If a maul can't break it, cut it in half.
Posted : 09/09/2024 8:23 pm
I used to, before I was aware of their health impacts.
Posted : 09/09/2024 8:46 pm
 5lab
4dc79149-fe2b-48a6-9f0e-0cc07b3b3971-1_all_155335Ta, I'll give it another go with the maul, aiming for the edges. This is (a small part of) what I have at the moment..
Posted : 09/09/2024 8:47 pm
 kilo
+1, we have a 5t one from forest-master, great bit of kit, if a little over kill for most.
Posted : 09/09/2024 8:48 pm
Sooooo, my first call to a local managed woodland who are a 20 minute drive from me and charge £210 for 1M3 of seasoned ash delivered and stacked = "sorry we don't deliver that far, we only like to supply people locally" FFS, welcome to the artisan intricacies of living in Stroud!!!
Posted : 10/09/2024 12:35 pm
We bought a splitter between 3 friends, 5.5 tonnes IIRC. If it fails I cut in half with the chainsaw as Timber suggests. Some things I know are going to be problematic such as big knots I just chainsaw into little stove-size lumps. Still haven't had to buy any wood in over 10 years and ignored a sign outside a neighbour's house offering free wood to collect - too much wood in stock to be motivated enough to get the wheel barrow and chainsaw out.
Posted : 10/09/2024 12:43 pm
Wally and Wally reacted
@qwerty - these guys should be close to you https://elcombefirewood.co.uk
Posted : 10/09/2024 12:57 pm
Not logs, but compressed wood briquettes instead.
I use these ones:
https://www.penntree.co.uk/product/hotblocks/
A pallet will easily last me a whole winter of a few fires per evening per week. They're using offcuts and waste from their pallet building business. They burn really hot and clean, my sweep always comments on how clean my chimney is. Broadly tidier than logs, but you will get a few chips of a briquette when you load them up.
Posted : 10/09/2024 1:14 pm
qwerty and qwerty reacted
@teaandbiscuits My second call was to Elcombe who will do 1M3 of seasoned mixed hardwood for £185 and I get to move & stack them myself.
He tried steering me to kiln dried and I've settled for a net bag of kiln & a bag of Hotmax fuel logs to try out.
Being delivered tomorrow AM.
---thumbs---up---emoji---
Posted : 10/09/2024 3:29 pm
Great! They arrive in a tipper pickup and just dump it out on the drive so its a workout to put it away but the wood burns well! I bought 1m3 last summer and we're about a third through it.
Posted : 10/09/2024 3:40 pm
If you've got significant amounts of timber to split then hire in a splitter.
For small amounts I have a fiskars xl27, it's a weapon but I wouldn't contemplate using it for more than an hour
Grenades are rubbish. If the fiskars won't do it a grenade won't. I have a proper forged wedge that is handy and far superior, they are worth having although you rarely see them. You'll curse when it's balls deep and going nowhere though.
If you must split by hand, pick your battles. It's generally obvious what won't split so don't bother doing yourself in over it.
Firewood processing for yourself is a serious pastime. Start now for next winter.
if you must buy in don't trust anyone to deliver properly dried timber. I see several suppliers locally, none of them store logs in a way that will season well.
In short, hire a splitter
Posted : 10/09/2024 5:42 pm
Honestly, this doesn't take as long as you might think. We get two builders dumpy bags of logs* delivered at a time (at £100 each FWIW, but we're up north), I always think "ugh, I've got to shift all that" but half an hour later, done.
*and I don't know what they are - they're wood, I store them under cover for at least a year so they're dry, I stack them next to the stove for a while so they're really dry, they burn.
Posted : 10/09/2024 8:28 pm
 mert
As they say over here, firewood warms you several times.
Felling, cutting, splitting, stacking, moving and burning...
Posted : 10/09/2024 8:55 pm
this doesn’t take as long as you might think
They're dumping them on the road, but, my house isn't on the road and includes a short sharp stint up one of the steepest lanes across a garden and then down two set of steps, and I'm still producing a faint line on today's COVID test...
It'll be reet.
Posted : 10/09/2024 9:11 pm
@qwerty with that description I don't think you'll find anyone that will deliver to your door.
As for everyone complaining about moving less than a cubic m (builders bags are .64 to .8 of a cube) I used to hand fill the trailer due to shed location and then hand unload due to it not tipping, could be moving 25+ cube some days.
Posted : 10/09/2024 9:45 pm
When we have to - seasoned red gum. It’s super dense and burns cleanly for hours. I mix this with anything else I get free. In reality thou - there is no natural gas where we are and the air pollution on still winter nights bits unbelievable. One of our kids has asthma so we’ve increased our solar and battery storage and run the heat pump flat out. Massive difference in her condition as a result.
Posted : 10/09/2024 10:18 pm
When we have to – seasoned red gum.
Probably tricky to get where the OP lives 😉
Likewise, mine is homegrown Blackbutt, Gympie Messmate, Tallowwood, Turpentine, Bloodwood. Biggest risk is that the termites eat it before I get to burning it!
Posted : 10/09/2024 11:49 pm
