What is the name of...
What is the name of this car part?
Part number 5 in the image. I know the entire thing is the air intake but specifically part number 5.
https://citroendirectparts.co.uk/product/citroen-berlingo-2018-2021-petrol-air-intake-pipe-bracket/
It's a bit loose due to a broken bit at the bottom and not sitting tightly at the rubber seal on the front. I could use cable ties to hold it in place for now. But ideally needs replacing.
Posted : 27/12/2025 3:44 pm
I can only tell you AI suggests
  • 5: The lower section of the air filter housing assembly, or an attached air resonator box, which helps manage airflow noise.
One of these?
https://www.ebay.co.uk/itm/267169696980
Posted : 27/12/2025 4:02 pm
Turbo-encabulator
Posted : 27/12/2025 4:19 pm
The same website says it's an "Air Inlet Neck Water Deflector" part number 98 109 208 80.
https://citroendirectparts.co.uk/product/citroen-berlingo-2018-2021-diesel-air-inlet-neck-water-deflector/
Posted : 27/12/2025 4:37 pm
Thanks.
Mines petrol so probably a different part to the above. I out a cable tie on for now untill i get round to replacing it.
Posted : 27/12/2025 5:35 pm
Looks like a resonator chamber to me, but could be known by lots of other names.
Posted : 27/12/2025 5:56 pm
Go to ilcats.ru (it's Russian, but it's benign as far as I can tell I've been using it for years) and put in your VIN.  Then you can get the electronics parts catalogue for your car, which is what the dealer has access to. If it is available as a part it has a number and you can order it from the dealer.
Posted : 27/12/2025 5:57 pm
Posted by: molgrips
Best use a VPN and a burner phone - someone might check your phone for malign usage, and think you’re sourcing iffy stuff on the Dark Web!
Posted : 29/12/2025 4:00 am
Posted by: molgrips
Posted : 29/12/2025 4:01 am
