Headtube badge. Not much metal- the commncal emblem.
Could I use no nails sparingly?
Or alternative. I dont want it overglued or fall off.
I have seen head tube badges stuck on with the double sided sticky foam tape stuff that is used for number plates. Don't know if this will give the look you want but may be an option.
3m make good double sided sticky foam, or whatever its called. iirc my sanderson headtube is stuck on with this, as is the one on t'wife's SC.
I've used [url= http://www.jbweld.com/product/j-b-weld/ ]JB Weld[/url] for exactly the same thing and it was spot on.
You can buy it [url= http://www.ebay.co.uk/itm/JB-WELD-WORLDS-FINEST-COLD-WELD-2-X-28-4G-/260825290521 ]here.[/url]
Where can I get...this 3m foam from??
[url= http://item.mobileweb.ebay.co.uk/viewitem?itemId=121090557090&index=0&nav=SEARCH&nid=09523272422 ]eBay[/url]
Probably the builders merchants of your choice, B&Q, Homebase...
[url= http://lmgtfy.com/?q=3m+foam ]Let me google that for you. [/url] ๐
Stixall - EverBuild
www.everbuild.co.uk/stix-all[url=www.everbuild.co.uk/stix-all]the best[/url]
Superglue Hora. Did the badge on the old 4X with it and its still (I guess) stuck there...
