Weird browser pause...
[Closed] Weird browser pause problem
5 Users
OK Normally I can diagnose/fix my own computer problems without much problem but this has me a little scuppered. 2 XP machines - neither can access a banking site (they can go through the login process but timeout), regardless of browser (tried IE, FF, opera, chrome). Fedora server machine on the same network accesses it fine with any browser. Went about killing off virus and spyware facilities on them - no improvement. Brought in my laptop, XP/IE - same "extra" software (avast etc) and it works perfectly.
I can only narrow it down to the machines themselves but I can't for the life of me identify the problem. Stuffed. Thoughts?
Posted : 10/03/2009 11:43 am
Have you tried pinging it?
Posted : 10/03/2009 11:46 am
[url= http://www.duxcw.com/faq/win/xp/secure.htm ]SSL is not working try these tips[/url]
Posted : 10/03/2009 11:48 am
No pingage seems to be allowed, even from the working machines. The site is actually accessible - its just the login process thats duff, it's as though a script or app of some sort is freezing up during execution - it pauses for ~2 minutes and then just stops as if the page is unaccessible. I'm assuming I'm running an old version of something *like* JRE maybe, but I've updated everything I could find :S
Posted : 10/03/2009 11:50 am
I had that with HSBC once. Ended up Turning off/Turning On and it worked on the third attempt.
Posted : 10/03/2009 11:54 am
😀 the off then on solution doesnt work, it's been over a period of about 2 months, before that it worked fine. Even risked the update to SP3!
Checking possible SSL problems, thanks muddy...
Posted : 10/03/2009 11:56 am
Check the hosts file for suspicious entries.
Think it's under %windir%/system 32/drivers/etc/hosts
Should probably just have a localhost entry unless you've changed it
Posted : 10/03/2009 12:12 pm
Will do, ta. Was in there not long ago and dont remember it but the user (parents) may have been fiddling.
Posted : 10/03/2009 12:24 pm
