Vista driver proble...
[Closed] Vista driver problems,
3 Users
 mrmo
got to the point now that i can get the laptop to boot into safe mode but it is hanging everytime i try to boot it normally. It will log in but freezes up once it has opened.
I am not sure why a 10month old laptop should suddenly decide to play up.
Because i can get safe mode i guess something in full mode isn't right. But how do i find out? what do you use to turn off drivers? I can only do this in safe mode.
Posted : 14/03/2009 9:40 am
10 months old? Stop trying to fix it and take it back to the shop.
Posted : 14/03/2009 10:06 am
 mrmo
that is next on the list of things to do. But as that will probably involve them sending it away to someone else, i was hopping a quick fiddle would fix the problem.
Posted : 14/03/2009 10:15 am
Do you have a recovery disc?
Posted : 14/03/2009 10:18 am
 mrmo
just found the "safe" place and giving it one more try. I had been restoring from the Hard Drive option
Posted : 14/03/2009 11:58 am
 PJay
It's probably worth doing a system restore to see if you can take it back to a time when it was working.
Posted : 14/03/2009 1:02 pm
 mrmo
i have been doing system restores and them not working? It looks like it may have worked 5th time lucky....?Touch wood, cross fingers, etc, etc, etc.....
Posted : 14/03/2009 4:30 pm
 PJay
Have you got automatic updates running? Microsoft Windows can be a bit naughy by installing things in the background without you knowing (although it may ask for comfirmation). I did it off and install manually (still using XP though)so at least if something goes wrong I know what I need to look at uninstalling.
You don't really want it happening again I supsect.
Posted : 14/03/2009 5:28 pm
