Vauxhall radio/cd r...
[Closed] Vauxhall radio/cd removal - Help!
7 Users
i need to get the code from my radio which is engraved on the side of the unit - so i need to remove it from the dash. how do i do it? is there a special tool or something? there seems to be 4 pins on the head unit.
its standard vx by the way.
ta very much!
Ben
Posted : 23/10/2009 2:14 pm
there is a tool , the dealer getting the code for you should be able to remove it. If your near Taunton Im at work and can do it for you.
Posted : 23/10/2009 2:20 pm
cheers knottie, but im up in sheffield!
ive just been looking online and the tool looks like a U shaped bit of wire. so im thinking of giving it a go with a wire coat hanger, i can get the code online for £3.50 so im gonna try and DIY it first
Posted : 23/10/2009 2:22 pm
i did it with four nails
Posted : 23/10/2009 2:26 pm
good suggestion - i'll give that a go too if the wire doesnt work.
can you do one side at a time, or do you hve to press all 4 at once?
Posted : 23/10/2009 2:27 pm
i think i did one side at a time
it may involve some swearing though iirc
Posted : 23/10/2009 2:28 pm
that doesnt surprise me at all!
thanks for your help chaps
Ben
Posted : 23/10/2009 2:33 pm
Why not remove the car instead and save yourself the trouble?
Posted : 23/10/2009 2:35 pm
You can get the pins to remove it from halfords for a few quid.
Posted : 23/10/2009 5:00 pm
I have a 02 astra and need to get the code myself , do you know if it is engraved on the side as well its a VDO CDR 500.
Posted : 23/10/2009 5:35 pm
same as mine mate - yeah it should be, havent done it yet
Posted : 23/10/2009 5:42 pm
Mrcrushrider, i'm up in crookes where are you, go halves on the tools if you want
Posted : 23/10/2009 5:48 pm
thanks for the offer stonemonkey but ive just got it off with 2 small nails, just press them in until they click then do the other side and it just pulls out - easy peasy!
Posted : 23/10/2009 5:58 pm
no worries is the code on the side?
Posted : 23/10/2009 6:23 pm
you code isnt on the radio . the radio serial number is.
thats what the nails/pins push down to slide the radio unit out.
Posted : 23/10/2009 9:08 pm
I have a code on the back of the fascia bit that comes off for security, do i still have to pay for a code then?
Posted : 23/10/2009 9:38 pm
I always used to find teaspoons were good for removing car stereos, but the police used to think I was on crack
Posted : 23/10/2009 10:13 pm
