upvc Window mechani...
[Closed] upvc Window mechanisms
Broke the handle off a top light window the other day because the shoot bolt mechanism is corroded.
How easy is it to get a window out, open it up and repair/replace the mechanism and fit new matching handles as there are at least three different types in the house.
Windows are circa 1980.
DIY or get an expert in?
Posted : 30/03/2022 11:26 am
Had to do the same recently, easy enough but took a few goes as my allen key (as per the first video link) wasn't long enough so had to use a metal coat hanger that was a little flexible. check off an identical window if needed to double check if your locks release inwards or outwards otherwise you may be tugging in the wrong direction.
Posted : 30/03/2022 7:16 pm
Thanks learn something new everyday.
Posted : 31/03/2022 10:15 am
