upvc window help
[Closed] upvc window help
7 Users
Hi.
Need some advice on double glazed windows.
Have a bedroom window which has two openers e.g. one half (side) of the window opens out, as does the other. Roughly 1m wide in total.
The openers have dropped and there are gaps when they're closed.
How much would it cost to have the two openers replaced (roughly)?
Thanks.
Posted : 02/06/2015 9:10 pm
Openers? As in the hardware, not the actual sash?
Posted : 02/06/2015 9:46 pm
No, the windows which open out.
Posted : 02/06/2015 9:56 pm
 chip
If the sash has dropped you can fix this by toe and healing the sash.
This involves shimming between the glass unit and sash.
Posted : 02/06/2015 10:01 pm
Sorry, they're not sash, just bog standard upvc hinged windows which open out
Posted : 02/06/2015 10:12 pm
If it's the PVC frame that's dropped, get a piece of timber, open the window, stick piece of timber through the gap and "bump" it back up, do it at each side (not in the middle) or use a block of wood and a hammer.
It's best to do it from the outside.
Posted : 02/06/2015 10:14 pm
Reckon all you need is new hinges. Should be stock item from any local repair company or local fabricator.
Posted : 02/06/2015 10:28 pm
I was wondering if hinges can warp etc
Posted : 02/06/2015 10:31 pm
Remove beads with a hammer & chisel, lift up sash on the dropped side, fit a packer between glass & frame. Replace beads, job done.
Highly unlikely there's anything wrong with the hinges, it's just dropped through normal use.
Posted : 02/06/2015 10:39 pm
Sash refers to the opening bit of the window. Doesn't have to be an old fashioned "sash"window.
No offence cheap windows are saddled with cheap hardware. However I'd be surprised if they'd dropped so much on the hardware to leave a gap. As above toe and heeling may help. If you replace the openers it'll look shit as they'll be a different colour, white just ain't white I'm afraid.
Posted : 03/06/2015 5:43 am
If they are the easy clean cantilever hinge type then they will be goosed, easy to replace though.
Posted : 03/06/2015 6:34 pm
