Unix shell help aga...
[Closed] Unix shell help again
4 Users
Can I use tar (or actually jar in this case) to extract a file from an archive and then pipe it directly to sed without having to create a temporary file?
I want to fish a string out of a file in an archive, inside a script.
Posted : 10/05/2016 5:35 pm
Ah it's ok, got it. Use unzip instead of jar, so you can use -p to output the file to STDOUT instead of writing it to disk.
Posted : 10/05/2016 5:38 pm
If it was a tar file and I wanted to find a string inside it I would just use zgrep and then pipe it from there, I'm guessing you could try the same with the jar?
Posted : 10/05/2016 5:46 pm
Molgrips, amazing how the brain and eye work. When was quickly skimming the subjects in this forum I thought yours was unisex hell, help. Imagine my disappointment.
Posted : 10/05/2016 8:15 pm
Most disappointing mis-read ever.
Posted : 10/05/2016 8:45 pm
As background, molgrips, jar and tar are not related. tar is a UNIX command but jar is one supplied only for java.
Actually, jar is much more like zip than tar.
Rachel
Posted : 11/05/2016 10:02 am
Yea I know.. hence use of unzip in the actual solution.
Posted : 11/05/2016 10:08 am
