long story short, did some ksh in the past, been roped into this, but have never seen this before in a ksh:
# Utility:Run:No. Var:Var.1:Var.2:Var.3:Var.4:Var.5:Var.6
# Remove the /apps/1/confg/s/sers directory
r_dir:Y:4:/apps/1/confg/s/sers
is it calling another shell script with the paramers Y 4 /apps/1/confg/s/sers ?
whats the purpose of the ':' why not the normal way of
r_dir Y 4 /apps/1/config/s/sers
or is this ksh file being read by something else and the ':' is a delimeter???
any help much appreciated.
That, I think. Is there a script called r_dir somewhere?
more google searching - wonder if its something to do with 'getopts' and using ':' ?
I think the comment on line 1 is a clue...
I don't think that the file is a script because there is no #!/bin/ksh at the start of the file. I suspect that a shell script reads this file for data and that the : are delimiters.
Is this the entire file?
Because if it is then as above r_dir must be somewhere else.
It could be an executable or it could be another script but that's the one doing the work.
from what you've provided anyway.
Taking a guess - there's a script called r_dir - you could always use
to see if that finds itfind / -name r_dir
Continuing the guesswork, this script, run from the command line will ask you to confirm it's action (Y to confirm), which would be the Run parameter. No idea what the number is
Based on
I'd hazard a guess that the script will delete the /apps/1/.. directory without asking for confirmation
thanks everyone, as most of you suspected and i did too and found it, its a parameter file to hold parameters delimitered with : thats read by a KSH script somewhere else
ta for the help!!!
