Under mounted sinks
[Closed] Under mounted sinks
5 Users
Carrying on with my Kitchen questions, I prefer the look of under mounted sinks, even though they costs a lot more, but I was just wondering, what do you do about a draining board?
Posted : 11/03/2010 12:50 pm
cut into the worktop
Using a jig like this, you router out grooves.
[img] ?rand=584029997[/img]
Posted : 11/03/2010 12:55 pm
Undermounted sinks are only suitable for use with either a solid wood (properly sealed) or stone (either natural or manmade) worktop, if you are thinking of having a laminate dont even got there after a couple of months your worktop will swell up like weetabix, if you re going for the above then as said they can be cut into the worktop.
Posted : 11/03/2010 12:57 pm
That wouldn't work on a laminate though would it?
Posted : 11/03/2010 12:58 pm
draining board is the least of your worrys if laminate so its a moot point really
Posted : 11/03/2010 1:00 pm
laminates and undeslung sinks are a big nono you cant seal the worktop around the cut out well enough to keep water out, dont do it.....
Posted : 11/03/2010 1:03 pm
