Tree surgeon types ...
[Closed] Tree surgeon types - Killing off a sycamore tree
9 Users
I've just lopped out one of those weed sycamores that seem to grow 10 feet overnight. Because of where it is I can't get in properly to dig the stump out, do i need to do owt with it? Is it OK to leave the stump in or should I treat it and if so, what with?
Posted : 09/06/2012 7:53 pm
Hire a stump grinder or get someone with one to do it. if you are looking to save a buck try pouring some diesel on to it - I've heard that works for most trees though some tree huggers might not like that. Then again they'd object to you needlessly slaying a harmless weed
Posted : 09/06/2012 7:56 pm
Re-cut the stump, then paint it with round-up.
Posted : 09/06/2012 8:15 pm
drill it full of holes then pour in diesel repeat for a while then torch it, stump grinder or chemicals stuff
You can dig under t attach a chain and pull the chain with your car but I would not actually recommend doing this unless you film it.
Posted : 09/06/2012 8:22 pm
Redneck styleeee ?
Posted : 09/06/2012 8:24 pm
Posted : 09/06/2012 8:25 pm
Speaking as an Ex forester. Drill holes in the stump and fill them with just about anything toxic From waste engine oil to cyanide ( under no circumstances do I recommend the latter). Bleach, Jeyes fluid, diesel etc will do the job. The best way is to remove the stump completely with a stump cutter (not advisable unless you know what your doing) or dig the whole thing out. Removal is the quickest greenest way.
Posted : 09/06/2012 8:42 pm
cheers gorehound. I can't get to it to grind it out (it's between a wall and a fence that isn't going to be shifting any time soon) so sounds like a drill and some strong (undiluted) weedkiller.
Thanks all for the more creative solutions too.
Posted : 09/06/2012 9:03 pm
If there's nothing you value near it, drilling some holes and filling them with ordinary salt might work. Well I've always wanted to try it.
Posted : 09/06/2012 9:34 pm
Salt will work. Amcide [Ammonium sulphamate] is good stuff too. Used to be marketed as a stump/ brushwood killer, but the for various reasons its now labelled as a compost accelerator, most garden places should have it. It comes as crystals a bit like sugar, so is easy to use and breaks down when gets into the soil, so the environmental impact is low.
Posted : 10/06/2012 11:18 am
