Tow bar bike carrie...
[Closed] Tow bar bike carrier
Does anyone know if anywhere in the UK sells a simple tow bar cycle rack similar to the ones I've seen in New Zealand.
Basically a metal pole that fits direct over the ball and is then secured with a grubber screw.
Simple and very effective.
Posted : 16/04/2015 8:42 pm
like these? http://www.maxxraxx.com/products.html
Posted : 16/04/2015 8:45 pm
I don't think that fits direct on to the ball ? Can't quite see on the pics
Posted : 16/04/2015 8:51 pm
[url= http://www.rv-rak.co.nz/FATB_two.html ]Like this[/url]
Posted : 16/04/2015 8:55 pm
ahh no, they bolt on.
Thule do a cheap one but it has 2 straps t secure it to your boot lid as well.
This is a cheaper version: http://www.halfords.com/cycling/accessories/cycle-carriers-bike-racks/avenir-kansas-2-bike-towball-fitting-rack
Posted : 16/04/2015 9:01 pm
The Thule 970 is rubbish. I found the unit moved on the ball causing the bikes to rub onto the bumper of my car. The carrier just clamps down and isn't secured in any way.
Posted : 16/04/2015 10:01 pm
If you have a bolt on tow ball I would look at the maxx racks.
Posted : 16/04/2015 10:03 pm
I've got a Maxx Raxx one, 4*4 version (off-set for the spare wheel). You need a bolt on towball. Unbolt it and fit a small length of pipe, then the towball goes back on. The when you wnat to use the bike rack, it drops onto the pipe. Works a treat, plus the arms fold down for torage when it's in the house/shed/garage. I'd be looking at one again if I was after another rack
Posted : 16/04/2015 10:08 pm
Thanks for the replies but still not what I'm after.
Pipe fits over towing ball, secured by a threaded bolt.
Posted : 16/04/2015 10:27 pm
http://www.aistoncycleracks.co.uk/
Posted : 16/04/2015 10:48 pm
Nope still none of those
Posted : 18/04/2015 12:24 am
Got a Thule 9708, bloody brilliant.
Drops on the ball, tighten bolt, secure.
Posted : 18/04/2015 9:10 am
We know none of those are not the one you linked to. But as you can't find the one you linked to they are the best available here in the UK.
Posted : 18/04/2015 12:47 pm
An alternative, if you're after a cheap and easy rack is one of these for £15
http://www.ebay.co.uk/itm/CAR-TOWBALL-MOUNTED-FOLDING-2-CYCLE-BIKE-CARRIER-TOW-BALL-TOWBAR-BICYCLE-RACK-/201295402318?pt=LH_DefaultDomain_3&hash=item2ede24154e
works very well, folds up neatly, can be fitted in 3 seconds. A liberal dashing of pipe insulation to protect the frame though. It's very secure, surprising amount of clamping force from the scissor action.
The two stubby arms folder over flush, then the two arms fold together. To clamp the bottom wraps itself round the ball as you open the big arms out. Its hard to explain, but I saw a friend had one and it's just perfect for taking one or two bikes short trips when I dont want to get the big atera 4x rack out.
Posted : 18/04/2015 12:52 pm
Love the Thule 9708 might end my search with that
Ta
Posted : 18/04/2015 7:25 pm
