If I try to create a new topic with safari on iOS, I get an error message that says something along the lines of ‘are you sure you wanted to do that’
using chrome, on the same phone it works just fine.
anyone see this behaviour or is it just me?
I get that message when I try to create a new topic on Chrome/Win 11. I have to use Edge if I want to create a new topic.
Sort of reassuring to know it's not just me.
"Are you sure you wanted to do that" appears when you try to post multiple times too quickly.
iOS browsers shouldn't vary because they're all the same engine because Apple.
Every forum page has a help button bottom left.
“Are you sure you wanted to do that” appears when you try to post multiple times too quickly.
It also appears in other circumstances, as alluded to above.
Yeah. I sort of reckoned that the team had enough on their plate, given that I have a workaround. I didn't realise it was happening to other folk too though.
which if you follow it through, tells you to email the moderators..
TBF, that is a bit crap. I didn't realise it'd changed, last I looked there was a form to complete which solicited further description / explanation.
It depends what option you select from the "How can we help" dropdown.
