[Closed] Toast
53 Users
Hot or cold before you apply the butter?
Cold for me.
Posted : 07/08/2016 8:52 pm
 Alex
What? Hardy worth toasting it. Hot toast melting the butter. Anything else is - just - not northern!
Posted : 07/08/2016 8:53 pm
[quote=Harry_the_Spider ]Hot or cold before you apply the butter?
Cold for me.
Posted : 07/08/2016 8:55 pm
Cold, if I'm applying Marmite after the butter. Hot if it's peanut butter or jam.
Cold. Can't be doing with soggy toast.
Posted : 07/08/2016 8:56 pm
Hot or there's no point.
Posted : 07/08/2016 8:57 pm
Kerrect.
Posted : 07/08/2016 9:01 pm
Hot toast melting the butter. Anything else is - just - [s]not northern![/s]WRONGER THAN A WRONG THING! Almost as wrong as putting the jam on a scone first.
Posted : 07/08/2016 9:02 pm
 Alex
soggy toast.
Look I don't want to come over here as a fired bread fundamentalist but if it's soggy you're doing it wrong. IT should be CRISPY. Any bread that come out of the toaster more floppy than it went in needs to be thrown in the local pond.
Next thing you'll be putting your beer in the fridge. It's a slippery slope.
People eat cold toast? Just have a cracker and save the electricity.
Posted : 07/08/2016 9:03 pm
Clickbait, surely?
Posted : 07/08/2016 9:09 pm
Hot, obviously.
Posted : 07/08/2016 9:11 pm
 Alex
- that's well meaning but the thing with a cracker is at least it has some stability in the horizontal plane. Whereas cold toast is a) horrible and b) saggy. There's almost nothing to which those adjectives can be applied in a positive manner and toast certainly isn't one of them.
Toast - warm
Lager if that's your thing - cold
Beer - Warm
It's not hard and I cannot understand why anyone has a problem with it 😉
Posted : 07/08/2016 9:12 pm
Toaster?
Has to be done under the grill for me.
Oh and butter applied asap.
Posted : 07/08/2016 9:15 pm
 Alex
And while I'm citing the Food Debrett's here, jam on an un-creamed scone is beyond an abomination. The jam needs to 'surf' on the cream. Next thing you'll be telling me you're rhyming scone with 'one'
Come the revolution comrades, names have been taken.
Posted : 07/08/2016 9:16 pm
If you're going to have it cold why not just cut the bread and leave it to go hard for a day or so before applying the butter.
Posted : 07/08/2016 9:18 pm
 Alex
Indeed.And in the spirit of enquiry I just toasted a single slice, left it to cool then added butter. All I can say is it's a good job we have a labrador as they'll eat anything.
Posted : 07/08/2016 9:21 pm
Clickbait, surely?
Quite obviously the work of Clem Fandango.
What? This is STW man. Toasting fork and woodburner surely?
Posted : 07/08/2016 9:22 pm
Well on the Scone thing I only have a cream tea when in Devon or Cornwall with local clotted cream, which is just one of the most delicious things. So the Clotted Cream is the star of the show with the Scone and Jam the supporting act. The first thing I want to taste and feel on my palette is the cream with the jam to come in afterward. Otherwise you don't get to taste the cream on it's own, it is contaminated with the Jam sitting on top right from the off.
Posted : 07/08/2016 9:24 pm
Cold toast?
Jam on top of the cream?
Posted : 07/08/2016 9:28 pm
You have to leave the toast to cool a bit, in the toaster, otherwise when you put it on your plate, you get a layer of condensation on the plate, thus making the bottom surface of the toast slightly damp.
Posted : 07/08/2016 9:29 pm
On the scone thing, I have no particular affiliation either way. Rather, it's one of practicality. Spreading jam onto a scone is easy, as is then spreading cream onto a jammy scone. Trying to spread jam onto half an inch of cream is like biting into a a vanilla slice.
Warm the plate, you amateur.
Posted : 07/08/2016 9:30 pm
Only one of these is right.
Posted : 07/08/2016 9:31 pm
Apply your butter and topping of choice on a board before transferring to a plate. That way you're not having to butter and top your second slice on top of your first one. I'm literally catching the toast as it pops up, on the board, butter on and Marmite on and first bite within a matter of seconds. It's a finely honed drill like an F1 pitstop.
Posted : 07/08/2016 9:36 pm
If I do that, I may as well use the grill, thus wasting the toaster.
Posted : 07/08/2016 9:38 pm
If using the grill is wasting the toaster, why do you have a toaster at all?
When the toast pops and you're buttering it, stick the plate on top of the still-warm toaster. Transfer buttered toast to plate, no condensation, no soggy bottoms. (Quiet at the back)
Posted : 07/08/2016 9:59 pm
I bow before the master toast maker. I will try this at breakfast.
Posted : 07/08/2016 10:05 pm
Brother from another mother!
Posted : 07/08/2016 10:10 pm
Where do you butter the toast if not on the plate?
You are Arthur "2 plates" Jackson and I claim my dead parrot
Posted : 07/08/2016 10:11 pm
Mine goes in the microwave for 20 secs after toasting.
Posted : 07/08/2016 10:15 pm
The problem with hot toast and marmite application is it makes it difficult to spread the black goo evenly, resulting in some areas that are eye-wateringly strong, and others that are barely skimmed. Allowing the toast to cool a little aids more even application and subsequently a more enjoyable toast experience.
Posted : 07/08/2016 10:16 pm
I do love it when we discuss the more important things.
The cold toast served in B&Bs is all your lot's fault - clearly the only acceptable way to east toast is hot, otherwise you might as well get it out of a packet.
Posted : 08/08/2016 12:43 am
Chopping board, it's a poor heat conductor so the toast doesn't get cold.
The solution there is more Marmite. (-:
Posted : 08/08/2016 8:06 am
Cold toast with a plastering of hard salty butter FTW.
I ain't no deviant.
Posted : 08/08/2016 8:17 am
Cougar - Moderator
Cougar - you are a sick and twisted individual and should be stripped of your privileges here forthwith!
Posted : 08/08/2016 8:28 am
The solution there is more [s]Marmite[/s] [b]BOVRIL[/b]. (-:
Also cheese toast (unbelievably NSFW content).
Posted : 08/08/2016 8:30 am
Stoner has it with the toast.
I have deviant tendencies
Jam before cream you dullards, you can get more of both on the scone which sounds more like "one"
Posted : 08/08/2016 8:38 am
 Alex
Stoner has history here. He's gloriously wrong on what constitutes a pie, and here again he transgresses into the territory of the unhinged. That combination sounds like something you give a prisoner 🙂
Posted : 08/08/2016 8:44 am
Posted : 08/08/2016 8:49 am
Cold toast? Eat it in your hair shirt? Crying? Cos mummy didn't love you enough to give you proper toast? You need help.
Posted : 08/08/2016 8:53 am
^This
With butter so thick you leave teeth marks when you bite into it.
Posted : 08/08/2016 8:54 am
[i]Where do you butter the toast if not on the plate?[/i]
Quarter-sawn English Oak chopping board/deli board obvs.
Posted : 08/08/2016 9:07 am
cold is just wrong.
annoys me when B+B's/hotels give you toast on an airing rack designed specially to make it go cold asap.
always have the toast before the full english / full scottish.
more marmite is always an acceptable answer.
Posted : 08/08/2016 9:12 am
Surely you wrap your toast in a napkin then place it in the bread basket prior to consumption?
Posted : 08/08/2016 9:26 am
Toasty means warm, therefore toast should be eaten warm.
Out of the toaster, onto the breadboard, butter on, then the topping.
Peanut better, marmite, (or both), jam, honey, pate or cheese. Your choice, so long as the toast is still warm.
Posted : 08/08/2016 10:32 am
this!
and woe betide anyone who inadvertently gets in the way as i race the 10ft from the toaster to the butter 😆
nb. plates are a bit of a waste of effort too. just eat it over the sink and get out to work like a normal person
Posted : 08/08/2016 10:33 am
Is the correct answer. I have conducted trials, and if the aim (as it should be) is to maximise the quantity of clotted cream, then an even, thick layer of jam allows for the cream to be dolloped on top, in industrial quantities.
Posted : 08/08/2016 10:54 am
I look to your sub-optimally designed toast preparation area with mild disdain.
Posted : 08/08/2016 11:06 am
To any entrepreneur reading this - I offer the idea of a four-slice toaster which ejects slices at one-minute intervals, in exchange for a promise of one of the first production batch. Do we have a deal?
Also have none of you lot discovered Vegemite? Like Marmite, but tasty.
Also have none of you lot discovered Vegemite? Like Marmite, but [s]tasty[/s] for weedy wimps who can't handle the real thing .
FTFY.
Posted : 08/08/2016 11:24 am
I've never actually had Vegemite. What's it like? I figure it's basically mild Marmite, but...?
Posted : 08/08/2016 11:27 am
Designed by the Antipodeans to actually be eaten unlike the stuff that was actually supposed to be thrown away....
Posted : 08/08/2016 11:30 am
Vegemite? Foreign muck. #wewantourcountryback
The earwax of a feral cat, much like Marmite.
Posted : 08/08/2016 11:31 am
Kickstarter. I'm in.
Posted : 08/08/2016 11:37 am
 sbob
doris5000 - Member
Why would your butter dish be so far from your toaster, unless it was in your fridge?!
You have been outed, and may leave at your earliest convenience.
Why would your butter dish be in the fridge?
Unless you are the-muffin-man and have it sliced..... in which case remove yourself from the human race post haste!
Posted : 08/08/2016 11:40 am
If the toast is cold, how will the chocolate sprinkles melt?
Posted : 08/08/2016 11:42 am
 D0NK
toast warms the marmite, makes it more spreadable, hence easier application.
cold toast is just hard bread, what's the point?
toaster needs to be prewarmed before putting your bread in so unless this is an incredibly complex toaster then doing it manually with a normal toaster.
Posted : 08/08/2016 11:50 am
Buttering Hot or Cold? Depends on its final application, especially if intended for use as soldiers with egg.
Hot buttered toast makes for rather limp, floppy soldiers that just can’t penetrate to the oozing goodness that awaits the insertion of a nice firm soldier!!
Posted : 08/08/2016 11:53 am
I counter with the idea of dropping slices of bread into a four slice toaster at 1 minute intervals. 😉
Posted : 08/08/2016 11:59 am
unfortunately it's a pretty tiny kitchen, so the toaster, along with the microwave, breadmaker and washing machine, have to go in this kind of side-room/back-kitchen bit. We only moved in a year ago and I want to just knock it all through but the wife demurs. I tried explaining about the ergonomics of toastmaking but, unbelievably, she still isn't convinced.
I have always wished for one of these! 😀
Posted : 08/08/2016 12:10 pm
[b]Cold toast![/b]
Out of my sight you [s]cretins[/s] croutons
Posted : 08/08/2016 12:16 pm
So, this cold toast. You take a slice of bread, put it in the toaster, and heat/toast it, correct so far? On completion of the heat/toast cycle, you take it out of the toaster, and let it go cold, before buttering, ensuring the butter doesn't melt, before eating?
WTF is wrong with you? How long does all that palaver take? Do you get up extra early in order to account for the extra time?
(My first thought was that people buttered 'raw' bread before toasting, which is less weird than the above)
Posted : 08/08/2016 12:22 pm
Yes!
But the toast has to be stood uptight while cooling or one half gets soggy with condensation.
There is an optimum coldness though, past that it goes leathery.
Posted : 08/08/2016 12:28 pm
You'd think with that username you'd know better
Posted : 08/08/2016 12:30 pm
If you reheat toast with marmite and butter it tastes like twiglets 🙂
Are you my doppelgänger?
Posted : 08/08/2016 12:45 pm
Yes!
Pretty much. You don't let it go cold, just cool enough to facilitate the application of spreadables wihtout a) tearing the bread apart, and b) an uneven finish.
Posted : 08/08/2016 12:46 pm
I see your problem here. You're making toast to look at.
Posted : 08/08/2016 1:37 pm
hot or cold?
both, thusly:
step1) put 2 slices of bread in a toaster, engage.
step2) when the toasting process has finished, quickly apply approx 100grams of crunchy peanut butter to 1 of the hot slices. eat.
step3) while eating, remove the second slice, and allow to cool.
step4) once you've eaten the peanut buttery slice, apply butter, then marmite to the cool slice, eat.
repeat this process 3 or 4 times a day.
Posted : 08/08/2016 1:57 pm
This thread has seen a great many members added to The List.
Posted : 08/08/2016 2:11 pm
Would this list be associated with The Wall by any chance?
Posted : 08/08/2016 2:13 pm
Hot, must be hot!
Posted : 08/08/2016 2:20 pm
Hot toast + Cold marmalade. It's all about the contrast. Delicious.
Posted : 08/08/2016 2:26 pm
But if you butter hot toast you end up with a crappy limp thing that's gone from a nice doorstep thickness to 1mm thick and soggy! 😀
Posted : 08/08/2016 2:30 pm
after the marmite slice there must also be a marmalade slice but using the marmite knife. the only way to clean the marmite knife is either on the fresh slice of toast before the marmalade goes on it (but only if you'll get a rollocking for contaminating the marmalade), or better still dip the marmite knife in the marmalade directly and it gets cleaned whilst spreading the marmalade.
Or clean it 'inside' the toast itself. Just pierce the edge of the toast and slide the blade in and out a couple of times. Job done.
The subsequent random bite of marmite/marmalade combination just adds to the experience.
Posted : 08/08/2016 2:35 pm
