Tips for removing w...
[Closed] Tips for removing wallpaper?
Plain wall paper and wallpaper on the ceiling preferably without removing the plaster.
Posted : 11/07/2013 7:50 pm
Paper over it, life's too short.
Posted : 11/07/2013 7:52 pm
I used a steamer (*don't overuse as it can impact plaster) and that made a big difference
Posted : 11/07/2013 7:54 pm
Steam stripper
Get one where the water is a separate base rather than the bit you hold. You arms will thank you after a few hours. Like this:
I'd hire one unless you have a massive house. The one above is £10 for a day from HSS.
Posted : 11/07/2013 8:10 pm
or just go buy a steamer from wickes, B&Q etc for 20-25 quid, hiring is just not worth it as all you seem to get is a bigger water tank. and by the time the smaller tank is empty you want a break anyway.
Posted : 11/07/2013 8:14 pm
I normally score the paper with the edge of the scraper then wet with a damp sponge. Just keep doing different areas so the water soaks in.
Posted : 11/07/2013 8:17 pm
pva solution brushed on seems to work well also. as above, don't let a steamer stay in one place too long unless you want to re skim the walls
Posted : 11/07/2013 8:27 pm
http://www.toolstation.com/shop/Painting+Decorating/Wallpapering/Perforator/d150/sd3252/p63466
You need one of theses, runover wall a few times gently, then some warm water with washing up liqyuid in it and aply to wall, paper will now peel easy.
or live in a flat and let the woman above have a new washing machine and not connect the outflow to anything and then go to work, leave for a few hours and wait until neighbour comes home, and finds water pouring down walls, and wallpaper coming off quite well.
Posted : 11/07/2013 8:45 pm
I normally just give it all a good wipe down with a very damp sponge and it mostly comes off nice and easy with a quick scrape.
Posted : 11/07/2013 9:13 pm
Join your local Freecycle and get/ask for one there. I got mine like that and our local group always seems to have one on offer.
Posted : 11/07/2013 9:16 pm
Cheers all - especially for the wicks steamer which had been most excellent.
Not sure sure I picked the best day to do it but that's 1/3 of two rooms done!
Posted : 14/07/2013 6:36 pm
No 1 tip - don't use a steamer on a day like today.... 😀
Posted : 14/07/2013 6:48 pm
