That's a prope...
[Closed] That's a proper cold winter jinxed
Seriously - how fast do you have to be going round a roundabout to 'nearly have it sideways' in a modern car?! Winter tyres aren't going to save you there, bud.
A good splash of oil or diseasel will do that nicely for you.
M+S marked tyres on the Motorhome all year.
Change the car tyres in mid-november when midday temperatures are around 5 and switch them back when I can smell them overheating in the spring.
Also ties in when I'm regularly heading into the chilly, snowbound north at the weekends rather than the temparate rainy, midge infested north at the weekends. Though since I'm near dundee that's basically a trip out of town
Posted : 16/11/2017 2:03 pm
 jimw
I know some will dismiss the following as merely anecdotal, but here goes anyway.
On the Skoda Superb 4x4 that I mentioned a few posts ago, the original fit tyres were Conti Sport Contact 5 225/40 R18. The winter tyres on Steel wheels were Bridgestone Blizzak Lm32 205/55 R16. The first winter I had the tyres I left the standard wheels and tyres, which by then had done approximately 4500 miles so had plenty of tread, on a bit late and experienced a few quite cold and damp days. On the poorly surfaced and generally ungritted small roads round where I live it was noticable that the fronts in particular were squirming about a bit even when being driven gently, made worse by mud etc that inevitably seems to get spread over such roads in the winter.
When I did put the winter tyres/wheels on, there was a noticable change in grip levels and reduced squirm on such country roads when it was cold even though in theory the narrower and taller tyres should reduce the turn in feel.
On straight, well gritted roads there was not any real appreciable change in normal driving, except that the winters were more comfortable due to the higher sidewalls.
So, in short, I am not Lewis Hamilton and I can tell the difference in gentle driving
So If I lived in more urban areas and/or spent all my time on the motorways then it might be the case I wouldn't bother. But I don't and also live on top of a hill on short section of an umade road so I do believe that it is worth it.
Posted : 16/11/2017 2:15 pm
Two pages and no evidence, just anecdotal stories!
Tyres have to pass a test to carry the mountain snowflake symbol, some details [url= https://www.oponeo.co.uk/tyre-article/winter-tyres-don-t-rely-on-the-m-s-mark ]here[/url]
Posted : 16/11/2017 3:17 pm
Real world experience. Same day, same car, same hill. Tried to exit driveway, no traction. Managed to reverse back up drive (cobbled driveway which was gritted heavily). Swapped to winters (same size wheels - spare set, i was being lazy). Drove straight out and up hill. Golf R awd.
Living North i find all weather/snowflake tyres much more predictable in colder and wetter conditions, upside is in snow they actually work better.
Posted : 17/11/2017 11:10 am
I use Michelin Cross Climates all year.
They are significantly better in the wet at any temperature, which is reason enough to run them in Scotland, traction is excellent.
The fact they work well in snow is a bonus but the reason I use them is mainly for how well they cope with day-to-day driving.
I won't go back to summer tyres
Posted : 17/11/2017 12:03 pm
[i] how well they cope with day-to-day driving.[/i]
Not sure what else they'd do... 😆
Posted : 17/11/2017 12:08 pm
Quite fancy some winter tyres myself as new house is comparatively high. Car is a low power FWD car and storage is an issue for spare wheels.
Would only putting winter ones on the fronts be a fools errand?
Posted : 17/11/2017 12:25 pm
For those people who say drive slower - I guess you also mean stop slower in an emergency? No ta 🙂
Shirley there's better ways of using your money. How much does it cost to get the tyres changed over and how much for the tyres?
Well it doesn't cost more after the initial outlay, because you wear the same amount of rubber off each year, but spread across two sets of tyres. And I change them myself so no cost. But they last ages anyway.
What do you think? Would you like to have far more grip on one end of the car than the other?
Posted : 17/11/2017 12:40 pm
The tyres that come on cars aren't the same as the aftermarket versions of the same tyres. They are crap and have really hard compounds. Just something to bear in mind.
Search youtube for summer vs winter tyre tests. Plenty of them.
Posted : 17/11/2017 12:43 pm
Straw poll on winter / all season tyre owners, what are you using?
About to have tyres done, so WWSTD?
Posted : 17/11/2017 1:01 pm
Works alright on my MTB...
Posted : 17/11/2017 1:11 pm
Depends on the manufacturer/model. Further down the pecking order you go, the more likely you are to get "special" tyres.
Posted : 17/11/2017 1:17 pm
 jimw
The sport contact tyres I mentioned were not the original fit ones-they were replaced at a local tyre fitter when I bought the car and had come from the well known huge tyre place just north of Winchester. So unless they were peddalling 'crap'........
Posted : 17/11/2017 2:39 pm
Molgrips, the clue is in the name... The cheap/OEM versions are the 2, the 5 is the AM version.
The 2 grips just as well (afaik it has the same ratings for wet grip at least) but wears down quite fast compared to the 5.
Posted : 17/11/2017 2:54 pm
The crossover is designed to be 7c. You may have your doubts but all the evidence is to the contrary.
But at what temperature do they work best?? I'm assuming that there is a gradual increase in effectiveness from 7 degrees down to a certain point not a constant improvement at every temp below 7?
Posted : 17/11/2017 3:08 pm
If 'winter tyres' grip better, why not just leave them on your car all year round?
& if so
Why not just make all tyres 'winter'? - why reduce the level of grip in the summer.
Posted : 17/11/2017 3:15 pm
Winter tyres wear faster in warm temps, especially on higher speeds.
Posted : 17/11/2017 3:22 pm
They wear very fast in warm weather and are usually noisier (although my nokian wr3s are noticeably quieter than my conti sport contact) and a fair bit worse on fuel efficiency. You could leave them on though, lots of people do, especially as they are getting worn.... They aren't so good with less than 4-5mn of tread left so still good for summer, leave on and wear out.
Posted : 17/11/2017 3:41 pm
I didn't think they did grip better in warm weather either. They get soft and squirmy. Or rather they are like that a bit but in the winter you are usually driving slower and don't notice so much those bits of performance where they aren't so good as summer tyres.
Posted : 17/11/2017 3:49 pm
I have an old 110ps Octavia TDi, and on cold wet days it’s not unusual to have the traction light flash on some road surfaces and junctions when pulling away.
Can't say I have this problem.
Posted : 17/11/2017 3:56 pm
That’s the next marketing stage, everyone will be driving around on winter tyres in the summer, and then a new fangled tyre called a summer tyre will come out offering more grip, quietness etc at temps over 7 degs. Because the marketing says it true everyone will swap their tyres
Posted : 17/11/2017 4:21 pm
Because the compounds and tread patterns (including all the sipes) on winter tyres are less than ideal if you are driving at "pressing on" speeds.
Think you've got it bad? In F1/rallying etc they have many more compounds to juggle.
Posted : 17/11/2017 4:28 pm
Too soft at higher temps, so squirm and also don't last as long. Sure, people get 20k miles from a set, but summer silica compound tyres get 50k so it's not that good.
Posted : 17/11/2017 4:44 pm
Have we picked up from last winters thread?
Lots depends on climate if you live in Southampton or Inverness.
Lots depends on the topography of where you live, and your councils ability to grit or plough.
Nothing is perfect, nothing is 'best' at everything.
Nothing stops you from crashing if you drive like a dick.
I noticed this morning that the Galaxy was a squirrelly beast, as I drove out of our road, at less than 20mph, on sheet black ice. Time for the winters.
Posted : 17/11/2017 5:56 pm
I live on the northern edge of Scotland's Central Belt.
In winter I have Nexen Winguards fitted to a Fiat Doblo. I drive like your Gran.
My commute is 20 miles, dropping from uptown 150m to sea level on rural A and unclassified roads. One of the A roads is not a priority route in winter and will have lying snow if it has snowed overnight.
Winter tyres make a huge difference. I have them on both cars and our Motorhome.
If you are a doubter, go to Cairngorm and watch non winter equipped cars and 4x4s try to deal with conditions on the access road or even in the car park. Yes. Some 4x4s struggle, and although there will be an element of driver behaviour, I am not a driving God.
I used to have Vredestein Snowtrac 3s on a diesel Berlingo. That was incredible in deep snow. Only grounding out on the floorplan would stop it.
Posted : 17/11/2017 11:02 pm
I used to be a doubter about winter tyres ... until I fitted a set to a spare set of alloys on the 4x4. Under sensible driving, there is a noticeable difference in grip when it gets icy or snowy, and even in the wet, I find the grip improved compared to the summer tyres I have.
On the dry, at speed, I find the opposite ( as you'd expect ) that the grip of winter tyres falls off quicker than when I have a summer type set of tyres fitted.
Posted : 17/11/2017 11:31 pm
OP, it’s ok, last month I took my winters off and put summers on, harsh winter guaranteed
Posted : 17/11/2017 11:43 pm
Just to annoy the driving gods on here, i am switching over to my winter tyres tomorrow.
I live in the south East but with temps below 7 degrees most mornings and plenty of damp days it is easy to feel the difference in the car.
I'm no racing driver but you can easily feel the difference and i like being able to stop without the assistance of the rear of someone else's car
Posted : 18/11/2017 12:06 am
Matt out and about's drive earlier this week
Posted : 18/11/2017 12:35 am
I live up a hill in the Derbyshire Dales. I set off for work in the dark and it has been below 4c every day this week. The council are horrendous at gritting around here, even on the A roads.
I drive carefully in these conditions, but why not have an extra bit of safety to help out just in case? While there is an initial outlay the total cost over the life of all the tyres and wheels I have is that of the rims I out the winters in (around £250 total for the original factory spec alloys I got secondhand for both cars).
Since it costs little more money and makes driving safer, why wouldn't I do it where I live?
Posted : 18/11/2017 8:44 am
The difference in grip level when the temperate drops is night and day with winter tyres.
The problem is perception as lots of people think it’s about driving in ice and snow when it’s about the rubber compound and tread pattern giving more grip when the mercury plummets. The only hassle is swapping the wheels over twice a year and storage.
Posted : 18/11/2017 10:25 am
@jekkyl - no, that was scotroutes drive...
Posted : 18/11/2017 12:13 pm
 igm
I find on my wife’s 320d that running summer and winter tyres actually saves money after the initial outlay.
Currently 103,000 miles on the clock, first set of winters and just got the second set of summers on. The winters don’t have that much left in them, but we’re still getting well over 50k a set out of them.
Most cars I’ve had recently do 25-30k a set, so even if the BMW is easy on its tyres, that’s good.
Posted : 18/11/2017 12:48 pm
That's pretty good going but a good third of that mileage is probably below the first set of wear bars. You'll still get some benefit from the softer compound but you'll have lost the help from the extra sipes and blocky tread if you encounter any actual snow or ice.
Posted : 18/11/2017 1:50 pm
Page 2 / 2
