Evening,
Thought it might be worth asking this on here, somebody must know something.
Basically looking for a switch/button like the one pictured below.
Its a pretty simple component, with 2 rubber buttons, and 3 wires coming out.
I have got 1, but need about 5 more. And cant find them anywhere. Anybody know anything...
Picture -
[img]
[/img]
Josh
Try RS Componants.
They're not the cheapest place you might find but they seem to stock just about everything.....
Or Maplin
Wombat, thanks for the RS website.
But just sat and looked through all there buttons and switches, and nothing.
Anybody else know how i can make a switch that basically has 2 buttons, one for up and one for down?
Its got to be simple, i just cant get my head around it.
Have had a quick scan of Farnell's website (www.farnell.com) but not found it. Worth dropping the picture and spec to the technical team though: techsales@farnell.co.uk
Ben
Just solder a couple of [url= http://www.maplin.co.uk/Module.aspx?ModuleNo=4196&OrderCode=KR89W ]these[/url] together or to a small piece of pc board? Don't think you're going to get something ready wired I'm afraid. Is this a project for a Mr Cancellara?
Ben,
Thank you for having a look, and giving me the email address. I have sent them an email, so we will see what they come back with.
Leffeboy,
Exactly what i was thinking of doing, but I cant get my head round the circuit they would have to go in.
I know it will be really simple, but its just not clicking 😯
Josh...
I'd think that you need to make your own by joining two single switches together. It's time to live up to your username 😉
You can get silicon switch shrouds from the far east easy enough, but they generally come in 1000's. One of these over what leffeboy suggests might be your only option, unless you can find some gadget cheap enough with a switch on it that you can take off
As TimS says. Join one side of each switch together and solder one wire to that junction. That's the 'common' wire if you like. Then one wire each to each of the other ends of the switches - that's your 'up' and 'down'
Ah, just rembered, try searching for 'lilypad arduino' suppliers in the uk. It's a wearable computer thingie but has [url= http://www.solarbotics.com/products/50468/ ]switches that are designed to be sewn into clothing[/url]. Some of those should do very nicely and might even be waterproof
Had a wee google to keep me amused - found this
[img]
[/img]
http://uk.farnell.com/jsp/displayProduct.jsp?sku=3717720&CMP=e-2072-00001000
or this [img]
[/img]
http://www.abcomponents.co.uk/B4D122N11100098000
or at teh bottom of this there are special assemblies
http://www.apem.co.uk/pushbutton.html
Just a quick thank you to everyone for the inputs.
Got it working now, a lot simpler than my mind was trying to make it.
Knew this was the right place to ask 😀
Josh..
A simple two way rocker switch is all you need!
