teach kids pounds a...
[Closed] teach kids pounds and oz in school
An Artillary Captain acquaintance tells me the military still use mils for added accuracy.
My physics teacher once got us to measure velocity in furlongs per fortnight.
(But yes, you're right, no-one navigates by milliradians, that would be daft)
Hangs head in shame at owning a FB prismatic compass in mils...
Posted : 01/10/2014 12:45 am
the reason we weigh babies is that any more than 10% of weight loss in the first week is a bad sign, their weight goes slightly down then they start putting it back on
Thats great but why do people feel the need to shout about it?
anyway metric for the win, and zero points for accuracy in the original post (or 32 in old money)
Posted : 01/10/2014 12:52 am
Don't forget that it might lower the cost of new European cars by several pence if they didn't have to produce a special speedo fascia for the UK
Careful, you'll have us driving on the wrong side of the road with that type of thought!
Posted : 01/10/2014 6:49 am
I would be quite happy with buying beer in 500ml glasses
There's no point. Why not buy them in 568ml glasses? That's a metric measure. There's no need to stop calling them pints, because you don't need to measure them out or interact in any way other than filling it to the top.
In france you can still (as I understand it) buy a pound aka livre of vegetables and similar. You get 500g, but you're allowed to call it a livre.
Re speedos, I once hired a car in the US that had a speedo without units on it, and you pressed a button to switch from kph to mph. Button was near the centre of the dash so endless fun could be had messing with it when the driver wasn't looking.
Posted : 01/10/2014 8:37 am
Always thought the baby weight thing had become a tradition due to a good weight being seen in the past as an indicator of a babies health (or likelihood to survive!)
Posted : 01/10/2014 8:51 am
I would be quite happy with buying beer in 500ml glasses,
The tabloids would explode. "Get your hands off our pints, Pierre!" they'd cry. Or something.
Aside from the fact that it's a smaller measure, can you imagine the British public taking to a system where you could order beer in either halves or quarters? We'd have to introduce the litre stein like the Germans as a third option, and that would get messy.
Posted : 01/10/2014 8:59 am
I always thought it's so other women could wince sympathetically.
Posted : 01/10/2014 9:00 am
Or make it 600ml and then there would (hopefully) be less complaining about being "ripped off" by a move to metric.
But molgrips is right, just mark the pint glass as 568ml and carry on.
Posted : 01/10/2014 9:03 am
Eh? Surely that's like saying metric is useless at measuring big distances because a metre is too small.
Isn't megapascal or gigapascal the appropriate magnitude?
Yes, it is, I didn't say it's a big problem, but its a minor pain in the bum if you are wanting to do a quick check with a calculator and a pen because your sizes will be in mm, so your cross sectional areas for stress are in mm^2, your loads will be in kN because a N is too small, your pressures for fluids will usually be in bar, or if not in MPa, your yield stress of the material is in MPa. But you want to punch the numbers into the calculator in m, m^2, N & Pa to minimise the chances of losing track of the decimal point on the answer, so you have a whole lot of extra multiplying up and down by factors of ten on the inputs and the output. Obviously that's not a difficult thing to do and the fact that a MPa is 1N/mm^2 helps but it's just another place that you can make a mistake and get a plausible looking answer that's out by a factor of 10, 100 or 1000. As soon as you are using Mathcad, FEA or similar it's a non-issue, but for that most basic "roughly how big should this part be" check on a pad with a pen, for the kit I design, it's faster in inches, lbs and psi because you don't need to make even those simple conversions. Also a pound force and a pound mass are the same, 1:1, unlike N and kg, which saves a step. Nothing big but it's a little quicker and easier to avoid stupid unit conversion issues introducing an error.
I'm not suggesting that the imperial system is better, in many ways it makes less sense but suggestions that it's useless or difficult for engineering and science are just nonsense.
Posted : 01/10/2014 9:21 am
Scapegoat - Member
Not accuracy as such. Any method of angular measurement is as accurate as any other. Mils allow for quick mental arithmetic speeding up artillery aiming.
Posted : 01/10/2014 9:31 am
That depends on what you are actually concerned with. I am talking about very basic engineering and project management. Some examples:
Bar is excellent when dealing with ambient water pressure, 1 bar = 10m.
Also, when calculating quantities of free gas stored at pressure. It becomes a pain with psi and feet.
Fluid quantities - It is easy to visualise 1.0m3 of water which equates to 1 tonne. Try doing that in lbs and gallons.
I except that lot of it comes down to familiarity but for 90% of what I do at work the metric measurements work better.
Posted : 01/10/2014 9:38 am
I think this is at the root of it, which is what I initially suggested. Familiarity is a big part of what is easiest and the other part is that the different systems do suit particular things and it sounds like, for what you do, metric is easier as it would be if I was designing smaller equipment subject to smaller pressures and loads. For the size of kit the oil industry makes, imperial works very neatly and easily. The only thing we do in mm is fabrication drawings because standard steel sections and plate thicknesses are in mm these days, so that's what the fabricators use. The ISO standards quote both systems for standard flange and gasket profiles and pipe for pipelines is till sold and sized in inches.
Posted : 01/10/2014 9:48 am
As we have been doing with milk bottles for decades.
Posted : 01/10/2014 9:55 am
Page 4 / 4
