Talk To Me Abbout C...
[Closed] Talk To Me Abbout Coffee 🙂
[#2108349]
OK, I've come back from my travels addicted to the stuff,
However, from my limited experience..............
Instant tastes crap.
The stuff (apparently a latte, I hate english-isms of other languages, I'd like a large cup of milk and a toasted sandwiches) I had from AMT this morning wasn't much better.
In Spain we were drinking Caffe con leche (1 shot expresso, 1 shot scalded milk, 1 sugar), will I get looked at like a muppet if I ask for that?
Secondly, just bought a 1 cup stove top machine, recomend me some coffee to go in it 🙂
Posted : 20/10/2010 11:24 pm
illy and lavazza are both good despite what the coffee hipster tarts tell you
Posted : 20/10/2010 11:26 pm
[url= http://www.hasbean.co.uk/ ]http://www.hasbean.co.uk/[/url]
Posted : 20/10/2010 11:35 pm
http://www.happydonkey.co.uk/
Posted : 20/10/2010 11:42 pm
For beans go with Illy or Lavazza as above, you can fart around with fancy stuff too if you happen to live somewhere where you can buy them easily but its difficult to decide what to look for if you don't have a benchmark for what you like, so get some Illy - its middle of the road but its good middle of the road - , get some practice at making a cuppa you like (play around with the dosage - chuck a splash of hot water in after you've brewed it to see what happens maybe) then buy other stuff and see how it compares, if you're experimenting try to buy new/different beans before you've finished the old ones otherwise its hard to put your finger on why you like one more than the other.
Posted : 20/10/2010 11:51 pm
Instant coffee is not actually coffee, technically it's more closely related to gravy granules and wallpaper paste.
Those stove top things are okay if you need a quick hit of coffee but I find that they do tend to burn the stuff if you're not careful. A cafetiere will get good results more consistently (leave the water to cool for maybe a minute after it's boiled, give it a stir, and press straight away). Obviously it's nothing like proper coffee from a proper espresso machine, but proper espresso machines are a bit pricey and a bit of a faff for a quick cup...
I really like the [url= http://www.unionroasted.com/discover/organic_ethiopia_yirgacheffe.htm ]Union Roasted Ethopian[/url] at the moment, very nice stuff, not too hefty for regular use, but not bland either. [url= http://www.grumpymule.co.uk/ ]Grumpy Mule[/url] coffees are also generally ace.
Posted : 20/10/2010 11:53 pm
that's the received wisdom, but I've found the flavour is better with freshly boiling water...
Posted : 21/10/2010 12:06 am
Tesco gold blend, you can't beat it. 8)
Posted : 21/10/2010 12:14 am
 nonk
sfb you are just wrong mate 😆
however who am i to tell you that you shouldnt like burn coffee.
Posted : 21/10/2010 12:26 am
Con Leche is a bit like a Flat White, Best machine i've found is the Rocket. Not cheap, but gives good results if you use a decent grinder as well. The downside of having an office opposite a coffee roaster (Cafe L'Affare) in what is considered the coffee capital !
Jesus - right i have been corrected by my resident Barista. He says a flat white has slightly cooler milk than a Con Leche and also is smoother as the milk is taken from the bottom of the milk whatsit so has small bubbles in it. Its a ****n minefield trying to get a coffee round here !!
Posted : 21/10/2010 12:28 am
yeah, I know that's the theory, but
a) I like the idea of burning stuff with water
b) it seems I prefer the taste of "burnt" coffee
c) isn't roasting the beans a form of burning ?
Posted : 21/10/2010 12:36 am
nonk, SFB isn't 'wrong' just because he likes his coffee a different way to you.
Stove top, some beans, grinder. Heat until it starts bubbling, take off heat to finish. Millions of Italians manage this every day without fuss. regular beans is fine, no real need to spend over the odds from t'internet, it's often not much different. Waitrose have a decent selection of very good beans for £3 for 250g which lasts me about a week
Posted : 21/10/2010 12:37 am
 nonk
nickc note the 😆
Posted : 21/10/2010 12:43 am
I might get burnt (with water) for this, but, it's worth trying a few different instants. A lot of folks seem to try standard nescafe or similiar and conclude all instant is horrible. Personally I prefer the nescafe suraya and alta rica to most proper coffee I've had. Tastes vary o'course.
Posted : 21/10/2010 12:53 am
making toast is a form of burning but most people don't like the taste of charcoal.
Posted : 21/10/2010 1:04 am
exactly, and if coffee beans aren't burnt by roasting at several hundred degrees C, they won't be burnt by water at 100 C 🙂
QED
Posted : 21/10/2010 1:06 am
[i]Most coffee bitterness comes from over-extraction, which many people confuse for coffee strength. Over extraction occurs when the lighter flavorful coffee oils have been extracted, in addition to the bitter coffee oils present deep within the bean. The most common occurrences for over extraction are using water that is too hot, using too little coffee, and brewing coffee for too long.
Water is most of coffee. If you use boiling water, it will scald/burn the beans, and a bitter taste will result. If your drip coffee maker is known for burning coffee, then try wetting the coffee grounds with 1/4 cup of cold water.[/i]
Posted : 21/10/2010 1:21 am
 CHB
Loving all the duff information on this thread!!
Posted : 21/10/2010 7:10 am
While we're having coffee chat, whats the difference between a Ristretto and an Espresso?
Posted : 21/10/2010 8:47 am
Is a ristretto a type of moped?
Posted : 21/10/2010 8:50 am
illy & lavazza, neither are as good as Sainsbury's Taste the Difference Kenyan beans. Blue Mountain can be picked up on ebay pretty cheap if you look around and that s very nice.
One of the best things you can do to improve coffee at home is to get a burr grinder, mines a dualit one and its spot on. I use a Gaccia Classic.
Posted : 21/10/2010 9:02 am
I tried those recently and wasn't keen (and I use an identical set-up).
Not bad when coarse ground and put through the stovetop though but didn't stand up to an espresso brew IMO.
Posted : 21/10/2010 9:07 am
waitrose java cofee is my favourite.
don't you wait to plunge? lets it brew betterer
 Twin
Mellow Birds. 🙂
Posted : 21/10/2010 9:17 am
uh, the bean is ground to quite fine powder before extraction, so whatever was formerly deep is now exposed...
what if one prefers bitter coffee ?
pray tell which are the duff bits, how will we know your suggestions won't be the duffest ?
Posted : 21/10/2010 9:36 am
maybe use cheap coffee(possibly with Robusta beans in the blend) and use boiling water straight out of the kettle, leaving it to stew may help.
maybe you could actually boil the coffee to extract max bitterness?
Posted : 21/10/2010 10:05 am
Get yourself a machine that takes the nespresso pods. It's the best coffee you can get. There are 16 different 'Grand Crus' and it takes a while to be able to understand the subtleties of each one.
Posted : 21/10/2010 10:15 am
will you tell him or shall I?
Posted : 21/10/2010 10:17 am
so the packaging is important ? I prefer to grind freshly roasted beans from a shop here in Lancaster...
Posted : 21/10/2010 10:18 am
no, let it stew a little more.
Posted : 21/10/2010 10:23 am
the difference between a ristretto and an espresso is about 5 seconds
Posted : 21/10/2010 10:36 am
I've progressed from instant to supermarket pre-ground + cafetiere to supermarket pre-ground + aero-press so far this year so still a newbie. The aero-press was worth it though, now I need to start either buying beans and grinding myself or buying fresher pre-ground from the net but I actually enjoy the current coffee enough I haven't bothered yet.
Posted : 21/10/2010 10:41 am
For low cost, low risk pleasant coffee, get a stove top espresso maker for about £20. Take a little care over it but in terms of quality of coffee to price ratio, they are impossible to beat.
Unless of course you want to compete with the Joneses which most of the "I need a £500++ coffee machine + £100++ grinder + beans" brigade are clearly doing.
Posted : 21/10/2010 10:46 am
sounds like envy there Mat, come on old boy do keep up 😉
Posted : 21/10/2010 10:56 am
maybe they do it because they like to drink perfect espresso at home?
sounds crazy but it is possible.
Posted : 21/10/2010 10:58 am
Oh yes of course, I wish I had a £2k coffee machine - really essential to my life...
Oh and of course I couldn't afford one if for some mental reason, I felt the need to get one.
They are like expensive watches - all for show and to keep up with the Joneses.
I have no interest in them when a simple and brilliantly designed little device does much the same thing.
Very random you STWers - spend a bit on a car and it's evil. Spend a fortune on a coffee machine and it's fine.
Ermmm...
Posted : 21/10/2010 10:59 am
No it bloody well isn't 🙂
Lavazza is okay but there are different labels or qualities. The gold label stuff is lovely (qualiatia d'oro), much nicer than the red imo (qualitia de rosso).
My fave machine at the moment is the Cuisinart one. My parents have one, I like the coffee better than my Gaggia, the auto dosing thing works better and the steamer works better too. And it game with a free burr grinder.
Posted : 21/10/2010 11:05 am
my expenditure:
30 year old Braun grinder my mum found in a cupboard: free
Bodum cafetiere from TKMax: £8
Ikea milk frother: 99p
stainless steel insulated mug: £1.99
Posted : 21/10/2010 11:06 am
For beans, I prefer Colombian dark roast. Strong & rich. The local roaster also does a blend call Feisty, which will have me buzzing all day.
you don't have to spend a fortune though. i paid £60 for a gaggia babyD (drip tray and lid missing) and £150 for a gaggia classic with extras (stainless tamper/filter/blind basket for cleaning/spare gasket)
a bag of monmouth espresso blend is only £5 and that will not get you 2 coffees from a coffee chain.
it's cheaper than buying from nero/costa/starbucks and to my taste is better than coffee from a stovetop and quicker to make an espresso.
i don't care how much your car costs, or how much it depreciates because you bought it new.
Posted : 21/10/2010 11:10 am
Lavazza or Lidl Arabica if you have no grinder, some stove espresso maker, a nice cup.
Music and sex [b]or[/b] milk and sugar
Posted : 21/10/2010 11:27 am
How long do you extract the espresso for? I seem to remember being told that 16 seconds is the optimum time - any longer and you get a bitter taste. (Using the double shot holder in a Gaggia)
Posted : 21/10/2010 11:34 am
This is quite true.
This is total crap 🙂
I've never met anyone who gives a flying F what their neighbours have. But maybe I don't move in the right circles 🙂
Posted : 21/10/2010 11:45 am
As in you run the water through the coffee for 5 seconds longer, or shorter?
What difference does this make?
Posted : 21/10/2010 12:00 pm
But all of this is just lame compared to sitting in a simple cafe in Italy/Spain/France/Portugal/Sweden drinking a freshly made cafe solo/espresso/whatever - how do they do it so well?
I've had many a coffee from a "home" machine from a £50 cheapo to a silly priced bean to cup machine - none compare to the "real thing."
I love the coffee culture on the Continent - our Yankified chains of coffee shops don't get anywhere near a simple set up in Europe.
waits for a stampede of mega bucks coffee maker owners claiming their machine is better
Posted : 21/10/2010 12:15 pm
Page 1 / 3
