STUPID photo
[Closed] STUPID photo
Can anyone see what is stupid about this photo? Grrrrrrr if not I'll be back in about 30 secs to tell you why....
Posted : 28/01/2010 8:47 pm
Sure can...it's just a little red cross!
Posted : 28/01/2010 8:48 pm
arg. even worse....
Is the sky upside down ?
'err I can see a bloke on a beach with a surf board... can't tell if it's a stupid board or not.
It could be an ironing board tho?
Posted : 28/01/2010 8:49 pm
Hard to tell if the surfer is walking towards the sea or away from the sea?
Posted : 28/01/2010 8:50 pm
How can some people see it and some not? 😯
Posted : 28/01/2010 8:51 pm
He's too far away from a socket to plug his iron in
the enormous bit of dust/thread on your sensor?
Posted : 28/01/2010 8:52 pm
it's the kings new clothes syndrome 😉
he's wearing a karate suit under a wet suit?
Posted : 28/01/2010 8:53 pm
Horizon is wonky?
Left side is lower.
If you stare at it long enough you can see the new shimano groupset... 😀
No (shame)
There's a bloody great odd mark just above the cloud line, about 1/4 way from the left hand side- I've No idea what's doing it...new lens and it keeps doing it- anyone know why?
Posted : 28/01/2010 8:54 pm
Well he appears to be carrying that enormous fish across his back in a very awkward manner - which kinda looks stupid.
Posted : 28/01/2010 8:55 pm
psychle - Member
hmmmm dust on the sensor you reckon? Is that an easy fix?
Posted : 28/01/2010 8:59 pm
Almost certainly dust on your sensor... what camera is it?
 igm
Agreed - or possibly on the lens somewhere.
Posted : 28/01/2010 9:00 pm
You could hardly expect people who don't know that it's reoccurring to have noticed that - it just looks like clouds/vapour trails/UFO to me.
That be dirt.
Posted : 28/01/2010 9:01 pm
Canon 30D
Doesn't show up in every pic.......
I thought you could all see the UFO 😯
Posted : 28/01/2010 9:03 pm
sorry to hijack, but i have the same problem.. its not a line but two spots...its not the new lens as i tried an old one and their still there...does that mean its the sensor? Is that easy or expensive to fix?
Posted : 28/01/2010 9:11 pm
Get a nice white sky/sheet of paper and take a photo of that.
Should show up exactly where the dirt is.
You have a mirror up mode in your slr as well which will lock the mirror out the way so you can clean the sensor.
Should be able to find some cleaning kits/blowers about somewhere then.
Possibly on the lense if not tho... earbud and some alcohol cleaner?
Posted : 28/01/2010 9:15 pm
At a guess - he should be surfing on a rising not ebbing tide and when the tide is higher?
Posted : 28/01/2010 9:37 pm
rocket blower about 7 quid from jacobs make sure you dont touch the sensor
or could be on the lense does it do it with other lenses
Posted : 28/01/2010 9:42 pm
Only noticed it on this lens - will have to give the whole lot a good clean..
Cheeers you lot!
Posted : 29/01/2010 12:03 am
looks like it might be a short pube.
Posted : 29/01/2010 12:10 am
i thought it was a massive swarm of bees on the horizon
Posted : 29/01/2010 1:09 am
first off, dust on most lenses is so far out of focus it just results in loss of contrast as its image is spread over the whole frame.
That looks like a sun trail to me, though I've not seen one on an SLR before. On EVF cameras where the shutter is normally open it's easy to damage the surface of the sensor, or the anti-aliasing filter, with a focussed image of the sun 🙁
Posted : 29/01/2010 1:15 am
don't about the UFO looking streak, but I can see like a dark kite/parachute type mark on it.
Maybe the guy forgot to bring the harness for kite surfing?
Posted : 29/01/2010 6:10 am
 igm
simonfbarnes - Member
Agreed - but it's easy to check by swapping lenses, so it's worth ruling out.
Posted : 29/01/2010 8:21 am
Looks to me like some dust on the lens.
And the horizon's wonky.....
Posted : 29/01/2010 8:26 am
I'd have said it's on the sensor or it's huge and on the lens, and having enlarged the image to 400% the rest of the sensor look ok.
If it's on the sensor, it will be on every picture after this image (or thereabouts), unless its dislodged itself.
Be very careful cleaning this sensor, don't go blowing onto it. Get to Jessops or some such camera shop and buy a brush or kit.
Posted : 29/01/2010 8:32 am
I seem to have an eyelash or some-such on the back of one of my lenses (it goes away when I change lens). I can't for the life of me see it on the rear element though, and it's certainly not on the front or the obvious on the sensor. Rather irritating as it's not that easy to clone out in Lightroom either. It seems to go and come back, but always in the same place. Tis very strange...
Posted : 29/01/2010 9:44 am
Zokes.
If you use Bridge in CS3, you can duplicate any healing applied to one images across all specified images.
This Master Class comes to you free of charge.
Posted : 29/01/2010 10:03 am
but a) pointless and b) possibly letting in more crap 🙁 Though you could test it by pressing the lens release and just slightly rotating the lens in its mount - were it to be on lens it would move...
good luck on that ever working! It's scene dependent.
Posted : 29/01/2010 10:21 am
Sadly I only have Lightroom, although I do believe you can do the same in there. The trouble is that it's usually on the cusp of the horizon, so clone works better than heal some times, depending on the angle of the shot. Not being a circle, it's not the easiest thing to subtly remove with the limited tools in lightroom.
Come to think of it, I suspect it is actually on the sensor, just that the other main lens (which doesn't seem to exhibit the issue) is rarely used stopped down very far. I seem to remember reading you notice more dirt the smaller the aperture, however if that's correct is another matter. I'm somewhat averse however to poking (however gently) the expensive bit of my £2000 toy, so I may take it somewhere to be done properly. It may even have shaken itself off by now...
Posted : 29/01/2010 10:30 am
What's that?? Only seem to get the problem in sunny conditions.. is it a permanent problem 😯
Posted : 29/01/2010 12:02 pm
What's that??
where the focussed image of the sun burns the surface of the sensor or the antialias filter. I had it on a bridge camera. Harder to get with a DSLR as the sensor is normally out of the light path and you avoid looking at the sun even through the viewfinder. Possible in live view mode.
Posted : 29/01/2010 1:28 pm
It's dust on the sensor I'll bet my left ass cheek, especially if it tends to go away with wider apertures. Get a rocket blower and [url= http://www.warehouseexpress.com/buy-LensPen-Lens-Cleaner/p1030276?cm_mmc=GoogleBase-_-Cleaning-_-LCD-and-Lens-Cleaning-_-LensPen-Lens-Cleaner_1030276 ]sensor pen[/url]
My sensor gets cleaned pretty much every month as I change lenses a lot out "in the field".
Posted : 29/01/2010 1:56 pm
BTW the aperture change may well explain why it "comes and goes". Check for the photos with it present and they'll be f8+ I suspect.
Posted : 29/01/2010 2:46 pm
explanation ? I expect wider apertures mean a wider cone of light which can get round the sides of the dust ?
Posted : 29/01/2010 3:07 pm
So this pic-
f16 , 1/1000, 200iso, lens at 28mm
Posted : 29/01/2010 3:12 pm
Yup, I think that's the general gist of it.
http://www.bobatkins.com/photography/tutorials/sensorclean.html
eviljoe - yup, guaranteed to give you some dusty issues. Get an out-of-focus snap of a white wall at F22 and you'll see the dust, use sfbs suggestion of lens rotation to determine if it's on the lens or sensor but I rarely see much of lens dust, even on the rear element. And F16 is likely to start degrading your image quality again due to diffraction IIRC, most DSLRs like the 20/30D etc start seeing diffraction softening at about F11 upward IIRC, depending on the lens to some extent.
Posted : 29/01/2010 3:19 pm
is it not in fact entirely independent of the lens and only dependant on the relative aperture ?
Posted : 29/01/2010 4:18 pm
That's what I thought, but I've been told that it also depends on your focal length to some degree. I've not put that much thought into the physics of it TBH, but intuitively I'd agree with you. Of course you're right with relative aperture, as it depends on the camera sensors pixel density AND the aperture rather than just aperture.
Posted : 29/01/2010 4:27 pm
