Community
Stupid car design i...
[Closed] Stupid car design ideas of our time
We've got a Citroen C3 loaner while our Golf is in being repaired.
The gear knob and the lower half of the steering wheel are covered in an alloy trim - the result is that this morning (and yesterday) it's like changing gear with a lump of ice.
Same goes for the steering wheel - you have to hold the lower section when turning sharper corners. Form over function.
Posted : 04/02/2015 9:45 am
You need;
you'll feel like Carlos Fandango wearing them as well, which can't be a bad thing.
Posted : 04/02/2015 9:47 am
most of the civic with the pointy bits to stab you, lack of visibility and mismash of spares bin parts to make a dash
My Wife's Astra, the seats have been designed to hurt me.
Honda Civic back window, why make it so hard to see when reversing.
My old Ford Focus (2000), no way to open the boot while at the door without a key.
Posted : 04/02/2015 9:51 am
Toyota Avensis button operated handbrake - shall we put the button where the conventional handbrake would have been? No. On the dash? No. How about under the dash, roughly half way down your shin so you have to feel about for it blindly like you would for the bonnet release? Brilliant.
Any car where you can't close the windows after you've switched off the ignition. So that pretty much any car other than a KIA.
Posted : 04/02/2015 9:53 am
Tiny rear windscreens and thicker-than-necessary pillars.
Narrow mirrors.
Moving the steering wheel across from Euro cars without swapping the lever functions.
Posted : 04/02/2015 9:54 am
AlexSimon - Member
Yes. Seat Leon is guilty of this, you could lose a bus behind the A-pillar. Also, what is it with VAG cars and their insistence that it takes 15 button clicks to open the car? One button click, open the f***ing car. One to lock it. If I own a Porsche in Johannesburg my feeling might be different but I'm a long way from either.
Last Astra I drove (previous shaped one) had such high window lines that I couldn't rest my arm on the door even with the window open.
Posted : 04/02/2015 9:58 am
This is all down to car safety and Euro NCAP
Posted : 04/02/2015 10:01 am
My old RX7 had a belter of a flaw. The petrol filling cap was only above the level of the top of the tank when you were parked level or facing downhill. Park facing uphill with a full tank and the petrol drained out, ruining your rear 3/4 panel paintwork 👿
The current MG has an odd one too. If your headlight/foglight switch has a fault, simply buy a replacement and fit it. Except the car's mileage is stored in the instrument cluster AND the light switch unit. Putting a new light switch unit in means there's a mismatch between the two stored mileages and your dash just reads 'ERR' instead.
Posted : 04/02/2015 10:03 am
Any car seat that has a ratchet system to adjust the recline angle of the seat.
Every one I've been in has never had enough positions to get comfy; either too steep or too reclined.
Cigarette ligher/power sockets that turn off when the ignition is off so you can't leave a phone to charge without the key in the ignition...
Recent headlight design that means you either need to remove half the front end of the car to access the bulbs or half the skin on your hands.
Posted : 04/02/2015 10:05 am
Once I tried to change a flat on a work's C8. Couldn't for the life of me find the jack.
After reading the manual (surely a sign of bad design) I discovered it was under the bonnet. Stupid enough I thought. Then I spent ages trying to find the bonnet release lever. Again had to consult the manual. Found it was under a hidden panel, on the passengers side! French cars are innovative just for the sake of it.
Oh and who puts the speedo in the middle of the dashboard, pressed up against the windscreen? I now just guess my speed in relation to other vehciles...
Posted : 04/02/2015 10:09 am
The move to isofix rear seat and then claiming that's why the seat base doesn't fold up. I don't want to fit kiddy seats but I do want to carry bikes.
Onzadog - Member
That's weird. My car's got isofix and the seat bases fold up, so clearly not a limitation of the system.
Posted : 04/02/2015 10:12 am
My missus has a type R (three door) and to get in the back you move the front seat, which is fine.
But it does not return to its original position, which means every time you do this you have to faff about with the bloody thing.
Perhaps the people designing them should actually use them.
Posted : 04/02/2015 10:16 am
[i]"Any car where you can't close the windows after you've switched off the ignition. So that pretty much any car other than a KIA."[/i]
On my ford you just hold the keyfob button down till they close, same on the Octavia and my old saab....
Posted : 04/02/2015 10:18 am
I think that is a good safety feature. Whilst it's inconvenient, you know people would be forgetting all over the place and flattening their batteries. I know I would, eventually.
Hired a Citroen C4 Picasso a while ago. They seem to like putting the pedals about 10cm to the right of where your feet should be, which is annoying enough, but for some reason they opted for acres of blank plastic in the centre of the dash, with the heating controls down low by your right knee. That means that you can't adjust them without taking your eyes completely off the road and looking down at the floor. Because this is quite dangerous I'd ask the passenger to do it, but they can't reach! Now that's stupid design.
Posted : 04/02/2015 10:24 am
The current trend for using multi function touch screens to control the heating - scrabbling about for menus is probably worse than being on the phone PEUGEOT!
Posted : 04/02/2015 10:26 am
ford something or other (fiesta or focus), with huge vertical distance between pedals. almost missed the brake pedal once or twice, or hooked sole of shoes on it.
all new cars, with stupid euroNCAP pillars that are now so frickin' wide they've had to start putting windows in them.
all cars, not even just new ones, not designed for people > 5ft11. don't recall the last car I drove where I could see the top part of the speedo without ducking. that's at 6ft2, steering wheel at furthest reach and highest adjustment. good job I can still see and stare at the 20/30 mph section outside schools with flashing 20 zone lights 😉
Posted : 04/02/2015 10:33 am
i don't think you can blame a flat battery on the manufacturer..
Posted : 04/02/2015 10:37 am
new cars that need the cluch depressed to start. i never knew looked a right **** when i called the aa out.
having to leave car doors open to fill up with fuel i like my van locked as i cannot see all the doors
Posted : 04/02/2015 10:39 am
Two. It takes two. Not really a big deal!
Yeah how dare they make us more safe! Bastards!
Last time I drove a pre-NCAP estate car I felt pretty vulnerable, it looked flimsy as hell!
Posted : 04/02/2015 10:41 am
isn't a flat battery.
changed my keyfob battery a few times, and the last time only seems to work in the vicinity of the drivers door. the range of the brand new fresh cr2032 was no better than the one I thought was on its way out.
seat leon so same key etc.
15 clicks is a bit of an exaggeration. 4-5 for me typically.
But Kia make it easier for those who can't find the handbook and have never had a 'proper' car
Posted : 04/02/2015 10:42 am
My mates Peugeot's has a sat nav that cannot find destinations by post code, you need to know the street name and number.
At first I thought he'd just got the thing set up wrong, but no...it really only wants street names!
jam bo
andytherocketeer
Yes, I should include a hyperbole warning on all my posts. Sold the car now but it used to do my head in. One click opened the drivers door, but then it was another 2 more to open the passengers door, and another two to open all doors, or something equally stupid. Great when you are standing in the rain with a wife and two kids.
Opening the boot was similarly stupid.
Posted : 04/02/2015 10:43 am
I like the microswitch on the clutch for starting but then I've always deloaded the engine for starting anyway coming from motorbikes.
Any car with crap, dim reversing lights. It's one of the most awkward maneuvers you can do in a car and it would be nice to see where I'm bloody going!
[i] Park facing uphill with a full tank and the petrol drained out, ruining your rear 3/4 panel paintwork [/i]
You must be parking fairly close to the petrol station to have a full tank in an RX7. 😉
I think one of the worst designs I've seen was the front window/bonnet water draining on a 3 series. I'm not sure how many of them are like this but when leaves get into the drain holes the water backs up and then flows into one of the circuit boxes and fries the ecu.
Posted : 04/02/2015 10:45 am
bonnet release lever in the passengers side on right hand drive cars 🙂
Renault idea of removing the front wheels to change the headlight bulb
Posted : 04/02/2015 10:49 am
Not a feature on all Fords. Only those with one touch close on the windows (and hence the trapped finger sensor).
Posted : 04/02/2015 10:50 am
One thing that annoys me slightly is that when they create RHD cars they invert everything except the radio controls. On/Off/Volume seems to end up furthest away from the driver.
Seems to be a similar issue with the auto gear selector in the Passat. To put it into manual mode ie for sporty driving you have to move it *away* from the driver, so to change gear you have to reach - if it were a LHD car it'd be really close to you and much more comfortable.
Posted : 04/02/2015 10:52 am
I hate this,and it's lots of cars So this was one of my favourite things about the citroen I drove the other day
Posted : 04/02/2015 10:57 am
VAG remote opener one click for the drivers door, several manic clicks to open the passenger doors pointless and annoying.
Ford focus cup holders, obscure by the armrest, in fact most cup holders in most cars are crap.
Alfa 156 doors which come to a point exactly at neck height.
Anything from Vauxhall, there dashboards are modelled on 80's AIWA hifis.
Posted : 04/02/2015 11:00 am
A few years back the DSC (dynamic stability control) and ABS warning lights came on in our Ford Territory, and both stopped working. I checked the fuses for those features, both fine. That was the extent of my auto-electrical expertise so into the garage it went. Turns out we'd blown a brake light!
Genius idea from Ford. Hook up important safety features in the same circuit as high-use consumable parts. When the part fails, the logical thing to do is disable the DSC and ABS...
The same thing happened again a couple of weeks ago, luckily it was a $4 bulb this time and not $50 garage bill for their investigation work.
Posted : 04/02/2015 11:01 am
Never mind metal gear knobs, our cars have steering balls as MrsMC is disabled.
Huge metal clamp, right where you hold the wheel. Not been pleasant at 06.45hrs this week!
Posted : 04/02/2015 11:03 am
I was thinking about this. Manufacturers make controlling everything from the screen out to be a good thing but it's a cost saving measure and I think it's actually making things more difficult.
Seeing as you can now make a call on a phone just by asking it to do so, these multifunction screens seem more dangerous.
Posted : 04/02/2015 11:04 am
 br
[i]all new cars, with stupid euroNCAP pillars that are now so frickin' wide they've had to start putting windows in them.[/i]
The window is a sop to get passed the regs.
You've actually a huge blindspot, but it gets past this by having a window in - the regs are there to protect pedestrians/cyclists and motorcyclists.
Posted : 04/02/2015 11:06 am
molgrips - Member
Not really a safety feature is it? And how long would it take for my phone/Garmin/iPod/Bluetooth Handsfree etc. to drain the huge battery in my car...?
And if you forget - tough luck. You'll only do it once. You being forgetful shouldn't trump my requirement to use the power socket with the ignition off.
The VAG key thing really isn't that hard. One click opens the driver's door, two clicks open all doors including the boot. My brother was ranting about this on his previous Golf and how difficult it was to open the doors, as sometimes it worked and sometimes it didn't. I told him it was once for his door, twice for all doors. He reckoned it wasn't.
We went out to his car and I unlocked and locked it about 10 times, telling him whether I was going to open one door or all doors on each occasion, and managed it without issue. Gave him the fob and watched him randomly stab at the buttons, swear a lot and wander off saying it didn't work.
I think you can get a garage/dealer to turn off this feature via VAG-com if you really don't want it, so one click unlocks all doors.
Posted : 04/02/2015 11:07 am
Bimbler - Member
Safer to avoid an accident, rather than just rely on safety in an accident.
The lowering roofline towards the rear leaving a letterbox rear view is mostly styling.
Also not very difficult to cut the power once the battery gets to a certain state of discharge.
Posted : 04/02/2015 11:11 am
AlexSimon - Member
True - I meant to say that in my post and forgot!
My Wife's old Ka had a timer on the stereo so if you turned it on with the ignition off if would turn itself off after an hour. You could have something similar on the power socket.
Posted : 04/02/2015 11:15 am
Power socket in my focus is on all the time, found that out when i accidently dropped a penny in it, annother stupid feature 'ash trays', now only ever used for keeping change in, next to a verticaly mounted coin sized electrical socket! I now keep an extra spare fuse for it becasue I know something will fall out my pocket, onto the handbrake console and into the bloomin socket!
I almost caused a crash the first time i used my car in the dark after the missus had borrowed it. Set the wheel where i thought was comfortable (i like it low and close so my forearms are more level), turns out the top of the wheel perfectly covered the indicators and they failed to self cancel so i aproached a junction on the left with my left indicator and the car waiting pulled out as i approached at 30-40mph, the only thing tighter than the gap was my sphincter!
The kind of idioticaly simple thing that really shouldn't be possible! Stick the warning lights in speed/tachometer where they're always visible.
Posted : 04/02/2015 11:16 am
Those stupid daytime driving lights on modern cars.
Now everybody drives round at night with no rear lights on!
Posted : 04/02/2015 11:17 am
Not really a safety feature is it...
...to use the power socket with the ignition off.
Unless of course what you use it for is unsafe or accidental, say an actual cigarette lighter which you knocked getting out of the car, a crappy battery/charger which might be prone to catching fire.
Your requirement to [s]have your car broken into because you left your phone on charge[/s] leave your phone on charge in a [likely unattended] vehicle because shouldn't trump actual safety concerns
Posted : 04/02/2015 11:19 am
This is so trivial but it annoys me... My Mondeo has a 60/40 split rear seat, which is a really good idea. Except the rear bench is a single piece, so you can split the seats if you fold them forward with the base down (which doesn't work very well) but if you want the seats down properly it's all or nothing.
Buttons instead of dials for temperature controls- to go from cold to hot means holding the button for ages on mine. Oh and the standard stereo's volume/on off button was right in front of the gearstick so I kept turning it off when I shifted into third.
I was pretty spoiled by my mk1.5 focus, it was a bit of a nail but the ergonomics of the thing were just brilliant.
Posted : 04/02/2015 11:20 am
I'm pretty sure it can. I keep meaning to check if VCDS-Lite can change this setting when I next have it hooked up.
Posted : 04/02/2015 11:21 am
In our MX5 when you change gear into 2nd, 4th or reverse you half open a cup holder.
In the previous Audi A3 when anyone with normal length forearms changes gear into 2nd or 4th your elbow batters off a bizarre arm rest lump thing.
Any Ford where you wash the windscreen, it wipes the wipers, stops then does a last wipe a few seconds later, smearing the windscreen again.
Peugeot vans with the handbrake on the right and where the full beam for the lights is on a separate stalk on the same side as the indicator stalk which you move up or down to go to full beams instead of towards you/away from you. WTF?
Posted : 04/02/2015 11:22 am
-1
Best thing ever and certainly saves accidents. Don't DRLs switch on the rear lights as well (they do on our cars)?
Posted : 04/02/2015 11:26 am
Whilst I agree that the rear visibility left a little to be desired, the dash/cockpit was the best in any car I've ever owned.
Posted : 04/02/2015 11:28 am
Mercedes foot hand brakes. I never mastered entering a main road from a side road that was on a slope.
Drls are not automatic lights sharkbait.
Drl are little front lights that cars have on all the time.
I vote any car that has an outward opening door..... You know the type that ding the car next.
After having sliding rear side doors id be quite happy to have sherpa van sliding front doors 🙂
Certainly any family car should have sliding rears to help mum and dad get the kids in as ever time i see a car gettinf "doored" its from a parent strugling with the door and strapping the child in.
Posted : 04/02/2015 11:34 am
I hate the VW multiclick car opening, argghhhh, its stupid.
Audi A3 with only one cup holder in the front, its a £20K+ car and they can't count to two. Plus the ride, if I wanted bone shaking stiffness I'd get horse and cart.
Posted : 04/02/2015 11:36 am
Fair enough.... I'm coming from a the viewpoint of a Volvo owner of about 16 years - they've always called them DRL's but they've just been headlights with the main beam disabled, rear lights were always on.
Posted : 04/02/2015 11:40 am
I find it clears the bits of washer fluid than run back onto the screen. Which is what it's supposed to do.
Posted : 04/02/2015 11:47 am
Also peugeot and citroen cigarette lighter continue to work for 30 minutes after keys out ignition if you put it in eco mode, that is to turn off , remove key and put your radio on then off using the button on the stereo.
Now your 12v outlets will operate for 30 minutes.
Posted : 04/02/2015 11:50 am
dangeourbrain - Member
Your requirement to have your car broken into because you left your phone on charge leave your phone on charge in a [likely unattended] vehicle because shouldn't trump actual safety concerns
The cigarette lighter can be safely 'knocked'. If you knock it into the 'on' position (which would take a firm button press, rather than a knock, but anyway...) it will just pop up when it reaches temperature as normal. It won't magically pop out of the lighter socket when the ignition is off and set fire to the car. If it is not far enough into the lighter socket for be held in place safely, then it definitely won't be far enough in to actually turn on if 'knocked'.
Crappy battery/charger catching fire - very low risk. Especially if you don't buy cheap crap. I have used 10's (perhaps hundreds) of different chargers over the years for all sorts of purposes both in and out of the car and never had one overheat/explode or catch fire. I'd say the risk is low enough to be negligible.
So, my car might be broken into. Yeah. OK. I can use my judgement about when might be safe to leave a phone in my car unattended.
The one time my car was broken into, I had forgotten to take my phone with me, and get this.......it wasn't even charging!!
When I'm camping, my car is right next to my tent and I want to charge my phone....is it safer to:
a) unlock car, plug phone in to charge and re-lock car, or
b) unlock car, place key in ignition to position II, plug phone in to charge, leave key in ignition, leave car unlocked (with key in ignition).....?
And that's ignoring cars that have a power socket in the boot, in which case you could plug things into them and leave them completely out of view from any would be crims.....
Safety feature - yeah, OK.
Posted : 04/02/2015 12:12 pm
trail_rat - Member
Ooooh, didn't know that. Will have to try it next time I encounter an unresponsive power socket. Cheers, t_r.
Posted : 04/02/2015 12:14 pm
Generation II Smart Fortwo headlight bulb replacement.
It was impossible to do without taking the whole of the front wings, bonnet and ariel off. Even if you trained as a gynocologist you had no chance of reaching the bulbs without doing any of this. Or an hour labour at Mercedes-Benz
Posted : 04/02/2015 12:18 pm
and you still legally need to carry spare bulb kit in several EU countries 😉
Posted : 04/02/2015 12:21 pm
Cup holders in my Clio that you can't actually get a cup/can in/out of without spilling, and if you're in 1st/3rd/5th you just can't get into at all. Then again, the entire interior seems to have just happened by accident
Posted : 04/02/2015 12:29 pm
I get grumpy about my rain sensing wipers and the automatic re-wipe thing on my ford... But it nearly works, and I reckon it's still better than manual. I just wish it had the option to revert to manual, or a little bit more user controllability. Things that nearly work can be more annoying than things that don't work at all!
I never thought I'd trust the automatic headlights but now it seems weird not to have them.
Posted : 04/02/2015 12:30 pm
There's a few that really annoy me, for example the centrally mounted instruments that small car manufacturers seem to love. I don't.
Vauxhall. Now, I've driven a few of them over the years but not one of them has had the steering wheel, seat and pedals properly aligned. All have had varying degrees of offset which have resulted in back/neck pain.
Now, I used to own a Mk 2 Golf, which was designed in the late 1970s. The seat, wheel and pedal position were perfect. All the controls were a finger top away and the stereo was almost at eye level along with the heater. The electric window switches were placed in the centre console, which meant you could raise and lower the passenger window at will. The seats were excellent and supportive and the visibility out of the car was first class.
VW got this right when most manufacturers were still dallying with vinyl seats and bakelite. Thirty five years on there's absolutely no excuse for any manufacturer to make a car that's uncomfortable to sit in and a PITA to adjust the heating.
Posted : 04/02/2015 12:35 pm
 br
[i]This is so trivial but it annoys me... My Mondeo has a 60/40 split rear seat, which is a really good idea. Except the rear bench is a single piece, so you can split the seats if you fold them forward with the base down (which doesn't work very well) but if you want the seats down properly it's all or nothing.[/i]
Funny that the my original Sierra had proper 60/40 folding seats, but the face-lift one had the stupid bench bottom.
Posted : 04/02/2015 12:41 pm
 br
[i] The electric window switches were placed in the centre console,[/i]
PITA having to search to the left when wanting to open the window to my right. Although better than (Alfa) having them in the roof console.
Posted : 04/02/2015 12:43 pm
Everyone complaining about the VAG multi click thing… you realise this can be turned off right?
Just a few clicks with the right stalk in the Maxidot/MFD.
Also Renault Megans, just in general - everything about them is a funking nightmare. Had one as a hire car snowboarding a few years ago, most infuriating heap of turd I've ever had the misfortune to drive.
Posted : 04/02/2015 12:44 pm
Posted : 04/02/2015 12:45 pm
 dday
Car radio (or ICE if you must) in wife's Renault. Get in, start the car, and a few seconds later, blast cheesy pop music (the kids) at full volume. And why cant the radio just turn off when I turn the car off? Why do I have to open the door first?
+ 1 for sat navs that can't search by post code.
Posted : 04/02/2015 12:46 pm
We had one of those! Alfa 164 or 75… can't remember the exact model. It used to look for all the world like you were giving the car behind the finger. Remember baffled by irate drivers until realising what it must have looked like from the car behind!
Hit the (car) power button a second time and it'll switch off. Personally I like this feature - great for when I'm waiting in the car to pick up miss mogrim from gymnastics, stop the motor but not the music.
Minor irritant: the chrome detail on the steering wheel, it catches the sun every now and then with an annoying flash.
Posted : 04/02/2015 12:57 pm
 hora
Headlight main bulb failed on my Subaru Forester and Halfords were doing an offer on pairs so I thought I'd change them both to equal brightness and pop the other in the box as a spare...
One the nearside you have to undo and remove the battery and its sleeve etc to gain access. 😯
So for now, I've left it as it is. I'll change it when it blows not twice 😀
Posted : 04/02/2015 1:01 pm
Vans that you can't get a coffee cup in, but you can get a can of coke in... If you drink half of it and rotate it 45 degrees to get the ****er in!
3 seater vans with 1 cup holder..
The 3rd seat in a Berlingo thing... Even a child would struggle to sit in that half seat!
As a lot have said, ignition turning off after 20-30mins, damn annoying when trying to charge your phone for work.
My car beeps when your turn ignition off and leave key in.. It's more like a flatlining sound, constant, ear piercing and not needed.
Posted : 04/02/2015 1:06 pm
 hora
Key left in ignition is another.
I KNOW - HOW THE HELL WOULD I LOCK YOU WITHOUT THE KEY IN HAND.
Posted : 04/02/2015 1:07 pm
As has been mentioned, this is a feature which takes 10 seconds to disable if you don't want it. And there is something wrong if you have to press it 15 times. Once for the drivers side. Once more for the passenger side. In fact I think some VAG cars with the higher end Maxidot type displays, you're able to disable this setting without the need to VCDS. You could choose whether to have it or not on my BMW.
A lot of what I've read is just people not knowing how to use their car properly.
Posted : 04/02/2015 1:10 pm
How about the requirement to take the front end apart to change a headlamp or the radiator? I remember, back in the old days, I could take the rad out of my Golf by removing four bolts and a couple of hose clips. These days, it's an hour's labour and the whole front of the car off.
I'm not even going to start on four seater cars that only work for adults if the driver is less than five feet tall.
Posted : 04/02/2015 1:11 pm
I had an Insignia with built in nav that did the same. Used to drive me mental.
On my alfa you can't lift the front windscreen wipers fully off the screen as the bottom of the legs rub against the bonnet.
Posted : 04/02/2015 1:14 pm
am i too late the mention the stupid, hateful, doesn't *ing work when i want it to... auto-dimming rear-view mirror?
what was wrong with the flippy-lever that rear view mirrors used to have?
i'll tell you what was wrong with it, *ing nothing, that's what.
****ing Vauxhall.
Posted : 04/02/2015 1:15 pm
DaveyBoyWonder
Anyway, another gripe - car stereo volume controls that you can catch with your knuckle going round a corner. Instant terrifying volume leap, doesn't help manoeuvrings.
Posted : 04/02/2015 1:16 pm
Passat does that. If you want to lift them you have to flip the windscreen lever down once after you've turned the car off and before you open the door. Flips them vertically. The hiding them presumably improves aerodynamics.
Posted : 04/02/2015 1:18 pm
and while i'm venting,
rain-sensing wind-screen wipers, they can *-off too. i've already got rain-sensors, they're my *ing eyes, i use them for (among other things) sensing rain, mine work better too.
having rain-sensing wind-screen-wipers is like letting a toddler choose when to operate the windscreen wipers, it's more or less random, and extremely annoying.
cars are like bikes, all the problems have been solved, every change from here on will only make things worse.
Posted : 04/02/2015 1:20 pm
willard - Member
There's a blown bulb in my dash. I've not even bothered to look up how to change it, I'm just assuming it'll be a 5 spanner job that starts "dismantle entire car"
Posted : 04/02/2015 1:31 pm
The bolt that holds the boot gas strut onto a Touran.
To access the bolt inside the rear pillar, you need to cut a hole in the bodywork, tighten or replace bolt, weld hole back up and re-spray back end.
I have an email from VW GB admitting it was an issue that they and VW Germany had no solution to, and were very sorry for.
(Or use a Riv-nut and epoxy as we did)
Posted : 04/02/2015 1:51 pm
Page 1 / 3
