Stuck valve cap (ca...
[Closed] Stuck valve cap (car).
8 Users
I have a metal valve caps on my cars, one is stuck. I've tried numerous evenings of GT85 application, and use of a hairdryer in an attempt ot expand it.
Any other ideas to save me paying the local Tyre shop for a tyre on/off new valve?
Posted : 05/10/2015 6:22 am
cut a slot across the top with a dremmel or something, then peel it off with pliers ?
Posted : 05/10/2015 6:24 am
Hair drier ... Hopeful.
Boiling water , pair of pliers and the right size spanner - or another pair of molegrips. - set them up so they fit and grip quickly.
Pour the boiling water over slowely then as soon as you stop - get the tools on and turn.
Posted : 05/10/2015 6:28 am
And then fit plastic ones.
Posted : 05/10/2015 6:42 am
I just had this problem with a cross-threaded one, in the end pliers + a bit of inner tube for grip was enough to get it moving
Posted : 05/10/2015 6:47 am
Two pairs of pliers, one for the stem one for the cap. Wear safety glasses in case you make a shop front of the job and rip the valve out 😀
Posted : 05/10/2015 6:58 am
Don't forget to take the other 3 off and fit plastic ones.
Posted : 05/10/2015 7:33 am
or just apply some anti sieze so they come off easy next time 😀
Posted : 05/10/2015 7:36 am
Cheers - I'll give the boiling water a go...
Posted : 05/10/2015 8:53 am
Just be carefull they are not the aftermarket jobbies off ebay. They have a grub screw holding them on and you will not get them off using the above methods.
The grub screw rusts in place and the allen key wont undo it anymore. A right PITA to get off
Posted : 05/10/2015 9:03 am
