Stereo advice pleas...
[Closed] Stereo advice please!
5 Users
 Rod
Quick question for people who know about this stuff...
I've got a decent stereo in the lounge with an airport express so we can play from iTunes/iPhone - that works fine. When we finish work on our dining room, I want to be able to add another airport express and use some old b&w speakers (dm600-s3 that were previously used as rear speakers for a surround setup that I no longer bother with).
I also have a Yamaha DSP E800 that I used to use for the surround set up (it worked with the existing stereo speakers and powered the rear/centre speakers). Is there any reason why I shouldn't/can't use this just as a stereo amp with an airport express as the only input? Or should I just get a basic stereo amp instead?
We don't need anything super loud and just need reasonable quality (iTunes will be the limiting factor at 256kbs).
Thanks!
Posted : 05/03/2012 3:17 pm
 Rod
Hmmm... just found the manual for the Yamaha online - sounds as if it's not flexible enough to do what I want?
Posted : 05/03/2012 3:31 pm
Probably not, as it is no doubt designed to work with surround signals only (or pass stereo through to your stereo amp for the fronts).
You can pick up a nice stereo amp from a few years ago for peanuts on ebay though. Or a basic cambridge audio one from richer sounds would probably be a cheap option too.
Posted : 05/03/2012 3:44 pm
I have a DSP-E800 and didn't think it could do that. There's nowhere to tell it to route the stereo to the rears.
There's no need to spend a fortune on an amp though.
I don't know what the current bargains are, but a second hand Nad 3020 or Pioneer A400 might fit the bill.
Although I don't think they are remote control.
You may not need it though - the volume may be adjustable from the source. Worth checking.
Posted : 05/03/2012 3:45 pm
Or anything by Rotel.
Posted : 05/03/2012 4:02 pm
 Rod
Thanks both - sounds like a plan (amp will be hidden in a cupboard so no remote isn't a problem). I assume these amps will sound much better than, say, a denon micro system?
Posted : 05/03/2012 9:24 pm
...I assume these amps will sound much better than, say, a denon micro system?
You'd really need to audition them to make your own judgement, perhaps? Especially bearing in mind your source... Don't be quick to knock the Denon micro systems; I have one in my study and it drives some large Mordaunt Short floorstanding speakers - and, for the record, I used to be a bit of a hi-fi nerd and can't believe how much I once spent!
Posted : 05/03/2012 9:50 pm
 Rod
Interesting... I might have to do some chatting in superfi and richer sounds one lunchtime...
Posted : 05/03/2012 10:54 pm
Look up tripath ta2024 on google, spend a few hours reading the various pages then buy a tripath amp from eBay for £20. Honestly, fantastic sound and for a second system, they are small cheap and remarkably good!
Posted : 06/03/2012 12:07 am
