As an aside have a look at the 50 dollar paint job website. Basically just a zillion coats of thinned hammerite and a thousand years of sanding!
If you arent fussed on finish, spray painting is a lot of faff.
Rustoleum or even 2pack rollered on would do. Just prep it, be careful not to go to bare metal. if you do go through i wouldnt bother with etch as it'll do more harm then good as it'll get under the surrounding paint.
cheers for all the pointers guys. Ive managed to find a local paintshop who understand what Im after (i.e. not a concourse finish, just a good solid, well lacquered paint job) and they will do it a a labour cost of around £40 ph + materials. Since Im going to do all the prep work, that should keep the cost down loads as they will do the whole lot in two batches in the painting booth. First lot is now just about ready to take down to them.
I missed this earlier.
I've had good results using Tractol synthetic enamel. It's used for painting farm implements and comes in lots of agricultural manufacturers and Land Rover colours. It sprays easily without the need for air fed masks. I used it to spray my IIA. It held a good gloss for about five years then went a little flatter, but it was exposed daily to Orkney salt air.
[img]
[/img]
Ive parked the idea of painting large panels at home as I dont think I can do it in a dry, warm, dust & bug free environment. Im doing the little things and internal bits like floor panel and seat box myself, but that's ok in the workshop in small doses.
I reupholstered the second row seat bases last week and have traded fitting a new bog and basin at my folks for mum upholstering the seat backs (stitching needed).
