Sparkies of the For...
[Closed] Sparkies of the Forum
I need 2 sets of 2 gang exterior sockets fitting? The firsty will be spurred off internal sockets and the 2nd will be trunked from the first around the side of my house. What should I be looking at paying?
Posted : 10/12/2020 2:14 pm
You usually can't spur multiple sockets from a single socket. You'll need a fused spur, then all your sockets will be limited to 13a between them. Probably not an issue unless you are planning a lot of high power appliances. Cost will depend on location and how much extra work needs doing with routing. The actual wiring up and parts will be pretty cheap.
Posted : 10/12/2020 2:46 pm
Materials around £60-70.
I presume you mean conduit rather than trunking?
2 2 gang sockets can come off the existing socket circuit, using a larger cable size.
Of course, if you intend to run a load of things with a current draw of over 20amps regularly from these sockets, then it will be different, and you'd be best with a new supply.
But, the common garden items being plugged in are usually low wattage items with limited use, like mowers/trimmers etc, so spurring off an existing circuit will be fine. I would be inclined to put an isolating switch inside, so you can turn off the outside supply.
They are meant to be very waterproof, but I have seen them full of water, if that happened, it'd be a right pain as your internal sockets will need to be turned off until they are fixed. A 20 amp DP switch would be perfect.
It'd take me 3 to 4 hours to do it properly, so if you can get it done for £200 all in, that'd be a decent price.
Posted : 10/12/2020 4:45 pm
