So, if you were stu...
[Closed] So, if you were stupid enough to...
8 Users
set fire to a non-stick pan, would it be ok to use it again or should it be binned?
Posted : 20/03/2010 12:23 pm
I would put out the flames first but then it should be fine
Posted : 20/03/2010 12:36 pm
depends on the accelerant and fuel I'd say
Posted : 20/03/2010 12:41 pm
No MrNutt, he should definitely put the flames out first
Posted : 20/03/2010 12:44 pm
Olive oil burst into flames!! Safely out now, thanks WCA.
Posted : 20/03/2010 12:45 pm
That's fine. I have lots of experience of things bursting into flames near me.
Posted : 20/03/2010 12:48 pm
Is this thread a wind up?
Posted : 20/03/2010 12:50 pm
No, why?
Posted : 20/03/2010 12:52 pm
It sounds as if you may have destroyed the teflon,personally I have an OCD problem with washing up so I simply bin frying pans after one use, you can't be too careful.
Your not a Teflon Don Simon by any chance?
Posted : 20/03/2010 12:57 pm
Set fire to it? or had a fire in it. if you just had a fire in it then it's fine. If you actually managed to set the metal burning....well done you, but I'd bin it. 🙂
Posted : 20/03/2010 2:46 pm
why use oil in a non stick pan?
Posted : 20/03/2010 2:50 pm
Ur mom mite getangree but chips dont tast diferint aftar theyve been on fire
Posted : 20/03/2010 4:32 pm
