So, following on fr...
[Closed] So, following on from my plumbing question earlier.....
todays lesson has been "Expanding foam corrodes copper pipe".
You have been warned ๐Ÿ™
Repair was on a pipe that ran along the top of ceiling joists (single storey so cold a breezy up the roofspace) and then turned 90 deg down through the ceiling into the downstairs cloakroom.
When we moved in 13 years ago I decided I didn't like the cold draught coming down the hole in the ceiling that the H&C water pipes used - so I squirted expanding foam around the pipes in the roofspace to seal the hole.
The leak today was under the foam and when I repaired it I found a couple of other points where the water was seeming through the pipe - must have been caused by the foam as the pipework is only 30 years old. Was trickier to fix than I'd anticipated but I think we're there now.
Thankfully I've not used expanding foam anywhere else!
Posted : 02/12/2014 4:01 pm
i was always told to use denso tape round copper pipes when using expanding foam near........
that was when i was mouse proofing the entry for my heating pipe work into the cavity under the floor - denso round the pipe , steel wool in the gaps - expanding foam in the rest.
Posted : 02/12/2014 4:29 pm
