SLR to DSLR questio...
[Closed] SLR to DSLR question.
8 Users
 juan
I know there is a few people on here interested in photography so I thought I'll ask.
Lets says that when I won't be able to process films anywhere I'll keep taking pictures using a digital camera.
Will my film lenses fit my DSLR body (owing no change of brand).
Posted : 06/04/2010 12:52 pm
Depends on the make, age and type of lens and camera. Some, yes. Some but with some limits (not autofocus etc). Some no.
Posted : 06/04/2010 12:57 pm
Depends what brand you already have.
IE, Old Olympus lenses probably won't be any good, certainly not without some sort of adapter. Nikon lenses have the same mount on all their SLR lenses, but there may be compatibility issues (mechanical/electronic interface and control). Canon lenses should swap over ok I think.
Bear in mind, that the DSLR sensor size is smaller than a 35mm film frame, so you will get a 'magnification' of the focal length of the lens. Typically 1.5x, so a 50mm lens will become a 75mm lens on a DSLR. The sensor only 'sees' a smaller portion of the image circle.
http://www.minasi.com/photos/dslrmag/
Posted : 06/04/2010 12:58 pm
 nbt
With reservations, yes. If your SLR is fairly recent, you should be OK, but some older lenses won;t work - e.g. Canon EF lenses will work on Canon DSLRs, but not the older lenses. What's your current camera / lens?
What CK said.
Posted : 06/04/2010 1:02 pm
 juan
canon EOS 300 lenses
Posted : 06/04/2010 1:05 pm
 nbt
juan - Member
Your Canon EF lenses will work fine on a newer Canon DSLR
Posted : 06/04/2010 1:08 pm
EF lenses work fine on EOS DSLRs IIRC, the reverse is not true though.
Posted : 06/04/2010 1:15 pm
If you're a Nikon man then most (if not all??) lenses from their back catalogue will fit as they have always used the same "F' mount. Ability to meter etc will vary according to the age of the lens.
If you are a minolta user then I THINK you can use some of their lenses on the new Sony stuff?
Canon have changed mount on several occasions so backward compatibility is limited.
Dunno about the other makes...
HTH..
Posted : 06/04/2010 1:33 pm
 nbt
coffeeking - Member
[b]EF[/b] lenses will work fine on any EOS camera
[b]EF-[i]S[/i][/b] lenses will only work on APS-C DSLRs - the xxxD and xxD ranges, in essence
No, just the once, from FD to EF. The EF-S mount is the same as the EF mount, but the lens projects further back as the mirror is smaller on an APS-C sized camera, thus the lens would foul on a full size mirror
Posted : 06/04/2010 1:41 pm
The only issue with Canon AF lenses is with the EF and EFS mounts. DSLRS have the latter, but can accept older EF mount lenses. Canon 35mm EF mount camera bodies won't accept the EFS mount lenses. Seeing as how the EFS lenses are designed for digital use only, this isn't really a problem.
Canon FD (manual focus) lenses won't fit any EF/S mount camera bodies.
Nikon FTW! 😀
Talkemada FTFail though. Curse you nbt! 👿
However if you have some non Canon lenses (ie Sigma) then some older ones won't work - they just throw up an error on the camera. It's worth googling the lens first to see if there are any problems.
Posted : 06/04/2010 5:17 pm
As they have said, and just times the focal length of your lenses by 1.6 for any APS-C sized sensor, and by 1.3 on an APS-H sized sensor. so anything below a 5D and the 1Ds will normally be 1.6 times with the exception being the 1D series (Different to 1Ds) in which it would be 1.3 times.
Chances are you wont have a wide angle now for most digital SLR's as 28mm therefore is equivalent of roughly 45mm.
Posted : 06/04/2010 9:16 pm
