Slow cooker pork sh...
[Closed] Slow cooker pork shoulder question for the chefs
Have a pork shoulder that's been well rubbed in spices which I want to get in the slow cooker early tomorrow.
Want this to be cooked through ideally to the point where it can be pulled when I get home. But I will settle for cooked and not shoe leather. ๐Ÿ˜†
The million dollar question is should I or can I put the meat in the crock dry (no extra liquid) or do we chuck some liquid in.
Liquid choices appear to be lager or stock as I'm not going to be arsed going up the shop now.
Posted : 02/10/2016 9:08 pm
 Bazz
Use some stock and some sliced onions/garlic, not too much just about an inch in the bottom.
Posted : 02/10/2016 9:10 pm
As above, a little stock.
I use a small amount of veg stock, to which I add some whole black peppercorns, Sichuan peppercorns, and some mustard seeds.
Hungry now.
I assume you have the skin off, ready to be made in to yummy home made pork scratchings?
Posted : 02/10/2016 9:14 pm
Never go in dry!
For stock....
Seriously, it's lovely!
Posted : 02/10/2016 9:28 pm
Bins, old chap, that's a stroke of genius! Will be trying that.
Posted : 02/10/2016 9:29 pm
Balls. Wish I'd thought of that earlier. No time now, 5am start tomorrow.
Thanks all.
Binners great idea (although I suspect it would get drunk before getting added) but Mrs g-d is not a fan of ginger in drinks or food ๐Ÿ™
Posted : 02/10/2016 9:34 pm
Things like dr pepper or coke work well too. I used irn bru once. I usually use plenty of liquid and take the lid off or reduce it in on the stove later on (metal inner for slow cooker is handy for this sort of thing). Not as good as a proper slow bbq (no bark) but good enough.
Posted : 02/10/2016 9:38 pm
Seriously, try it! It's bloody gorgeous! But if you really object to ginger then the captain has it.... full fat coke
Posted : 02/10/2016 9:40 pm
Don't forget to lift it off the bottom on some tin foil balls.
Posted : 02/10/2016 9:41 pm
To contrast, I go dry, maybe with a glaze but no more than that. Keep the lid on for as long as you can and it'll cook in its own juices. I don't lift it up either, means you have a bit of edge on it, lovely.
Technique from me is;
Big Le Creuset casserole dish.
Pork just sits on/in the stock. Nothing more.
Bottom oven of the Aga.
Turn it over after about 12 hours or so.
Yum.
Posted : 02/10/2016 9:46 pm
Another stock option....
Posted : 02/10/2016 9:48 pm
which one? I've been using the simmering oven - top left on mine, but still getting used to the aga
Posted : 02/10/2016 9:59 pm
Thanks binners that was plan A.
Apparently 'someone' may have drunk the last of the cider stash :mrgreen:
Use coke for gammon (yum)
We slow cook a lot but I've never tried dry roasting in it but it kind of seemed the right thing with a dry rubbed joint to not drown it.
As for the aga suggestion that'd be lovely but not in a suburban semi with a small kitchen ๐Ÿ˜€
Posted : 02/10/2016 10:00 pm
I use cranberry juice and some Thai spices on mine..Yum yum!
Posted : 03/10/2016 8:27 am
I prop mine on a few sliced carrots and potatoes and have the stock just touching the underside of the shoulder. Just falls apart after eight hours or so.
EDIT: Are you going to seal it in the frying pan before putting it in?
Posted : 03/10/2016 8:29 am
