Sliced bread etique...
[Closed] Sliced bread etiquette
Do you start with the crusty end first, or leave the crsuty end in the bag as a sacrificial anode to stop the next slice drying out?
Que, I dont eat sliced bread i make my own out of organic spelt that i hand rear in my orchard
No, what normal people do. Whrn you buy a loaf in a shop is it end to end or leave the crust fot halfway through
Discussions with colleagues about toasters equipped with photo electric sensors so your toast is always the ssme despite moisture content brought me here
Posted : 17/09/2021 6:20 am
Leave the crust unless you want to eat it, in which case eat the crust.
Posted : 17/09/2021 6:29 am
Moisture lock. Essential. Habitual.
And that's with hitherto unsliced homemade sourdough, or the pleb's stuff.
Posted : 17/09/2021 6:40 am
We don't eat much bread which means it lives in the freezer and is eaten as toast. Apparently, freezing does something to the resistant starch which is supposed to be really good for the gut biome.
Posted : 17/09/2021 7:00 am
Eat it as it comes!
BTW, in my world, the "crust" is the circumfrencial part of the standard slice of bread. The end slices are known as "heels".
Posted : 17/09/2021 7:18 am
Leave the crust to protect the middle. When you get down to four slices you have two crust/bread combos. That's normal square bread. For a fancy round sour dough just eat it as it comes as the crusty end is too small to do anything.
Posted : 17/09/2021 7:28 am
Left to protect the middle. Disposal depends on thickness; a pair of proper doorsteps get toasted and smothered in butter and marmite. Skinny crusts get binned.
Posted : 17/09/2021 7:33 am
If its an even number of slices, eat 2 at the time and leave the end crust till the end. If there's an odd middle slice left, you know someone has stolen a slice, forcing you to make an uneven sandwich.
Posted : 17/09/2021 8:13 am
There is nothing, but nothing, in this world better than a fresh, toasted crust of a new loaf.
Why on earth would you not enjoy that?
I suppose it separates people who are prepared to suffer now in the interests of their future, and those who live in the moment.
Enjoy that crust, when you put the bread back in the bread bin, put it cut side down.
Posted : 17/09/2021 8:16 am
this, it is to be covered in butter and consumed immediately.
However... round sour dough isn’t “fancy”, it’s normal bread. Cheap “bread” isn’t bread at all, but a BSO - Bread Shaped Object. Utter shite.
I suspect this is actually a very clever troll post by the OP to out the plebs... everyone knows you don’t need a sacrificial slice to prevent bread drying out, as the paper bag it comes in (or, more likely, you place it in after baking) performs this function.
Posted : 17/09/2021 8:26 am
Everyday is a school day. So does this count if you defrost the bread first or does it go from frozen straight in the toaster?
I tend to keep my crusts until my appetite decides I want one thickly layered with marmite and peanut butter.
Posted : 17/09/2021 8:32 am
Straight from freezer to toaster. Our toaster has a defrost setting
Posted : 17/09/2021 8:49 am
Cheap “bread” isn’t bread at all, but a BSO – Bread Shaped Object. Utter shite
I love my home made sourdough, but I also love a plate of hot buttery Warburtons toastie, utter heathen that I am.
Bread snobs unite! 😂
Posted : 17/09/2021 9:15 am
Is the right answer.
Posted : 17/09/2021 9:17 am
^^^^ That
as "Moisture lock. Essential. Habitual." is correct, then my partner comes along and just dumps the crust... almost annoying as her inability to cut bread straight GGGGGGGGGGRRRRRRAHHHG!!!!
But Kayak is also correct, I will happily eat a still fresh/warm crust, as it is a joyous experience.
Posted : 17/09/2021 9:47 am
 Esme
"For a fancy round sour dough just eat it as it comes as the crusty end is too small to do anything."
A better method is, once you've eaten around two-thirds of the loaf, place it cut side down, then slice in the other direction.
Posted : 17/09/2021 9:48 am
Top tip: you can use half a loaf of shop-bought-ready-sliced wholemeal as a hand warmer if you lock the moisture in and leave it for a few days to grow mould.
Is a a new thread needed on the topic of slicing loaves?
Posted : 17/09/2021 9:53 am
A better method is, once you’ve eaten around two-thirds of the loaf, place it cut side down, then slice in the other direction
With proper bread we start with slicing from the middle and work our way out to the heels. Biggest, squadgiest slices are eaten first and the almost-matched ends keep the moisture content fair. When we get to the heels they are either OK for hens or perfect for toasting depending on thickness and dryness.
I’m not bothered about BSOs. The children grab that out of the freezer when they want.
Posted : 17/09/2021 10:25 am
My OH would appear to cut bread with a wooden spoon or something.
I just don't see how it ends up the shape it does.
I have to bring it back to a clean 90 degree face taking long, considered strokes, elbow in line, index finger pointed along the blade as if using my fine toothed Japanese dovetail saw, applying absolutely minimal pressure and letting the [s]saw[/s] knife do the work.
Gauging the thickness consistently and perfectly to match the capacity of the vintage Dualit two-slice is immensely satisfying.
Next time, again, it looks like she's ripped a slice off with her bare hands... 🙄😂
Posted : 17/09/2021 11:25 am
@kayak23 😂
Posted : 17/09/2021 11:33 am
I just don’t see how it ends up the shape it does.
Sigh. Yes. I don't eat much bread these days, but in times gone by one slice of toast would have two parallel faces (or near enough, I don't have a fine-tooth Japanese bread knife or baker's set-square), and the other would have one flat face, and one resembling the altitude profile of a long day out in the Lakes or similar.
Posted : 17/09/2021 11:39 am
A thread on all things Breadiquette may suffice.
I'm still reeling from reading that there are people (other than my wife and MIL) that believe it's acceptable to toast fresh bread!
Posted : 17/09/2021 12:03 pm
 Esme
For some of you, this Even Bread Slicer might restore marital harmony . . .
Posted : 17/09/2021 12:13 pm
This on a stick and cut thick enough to [i]just[/i] fit in the toaster with a bit of force.
The end that's left that might end up drying out a bit just gets cut off and toasted and covered in peanut butter (the good shit, not the crap that's full of sugar and palm oil) eventually anyway so it makes no difference.
Posted : 17/09/2021 12:24 pm
 grum
I just bought one of these, mainly for the other people in my family to be able to cut my sourdough successfully 😛
https://www.breadboards.co.uk/carved-breadboards/bread-knife.html
Will report back once I get it.
Posted : 17/09/2021 1:01 pm
We use sliced bread in our house, (it appears although the OP was on this topic, I might acutally not be entirely welcome here) so no cutting issue there.
But cake! 😱 I watched my daughter do it once.
Get knife, (preferably the blunt one with the dodgy handle 🤷‍♂️ Why when the decent sharp ones are in the same block?)
Smash through in one sharp, brutal chop rendering half the remaining cake lumps and crumbs.
I blame her mother. Nice smooth sawing motion! Takes literally 2 or 3 seconds longer!
Posted : 17/09/2021 1:18 pm
 igm
What knife for…
Posted : 17/09/2021 1:43 pm
 TedC
“Moisture lock. Essential. Habitual.”
Is this a disguised “what3words” cry for help?
Posted : 17/09/2021 1:57 pm
Is this a problem down your neck of the woods ?,burglars break in, not for your car keys, not to steal your telly, but to deprive you of the odd slice of bread.
Or are you really possessive in your family, counting out the rice crispies 😆
Posted : 17/09/2021 3:14 pm
That is the ugliest bread knife I have ever seen. But, since it comes in a box on a bed of sycamore shavings I guess it must be especially good. Despite it looking like it would get stuck halfway down the loaf. Mind you, I’ve yet to encounter a bread knife that couldn’t cut bread.
Posted : 17/09/2021 3:17 pm
 grum
I feel sorry for you that you eat such crappy bread that you've never encountered a decent crust. 😘
Posted : 17/09/2021 3:36 pm
I feel sorry for you that you eat such crappy bread that you’ve never encountered a decent crust. 😘
Are you sure you’ve not been using a butter knife?
Posted : 17/09/2021 3:40 pm
 grum
Posted : 17/09/2021 3:44 pm
You looked but didn't see 😉
LOL at things get nasty about slicing bread 🤣
Posted : 17/09/2021 3:45 pm
I think I might be kayak’s wife. Whenever we have a tiger loaf I get shouted it for squashing it and apparently I’m supposed to cut it without holding it, which is just pushing a loaf of bread around the worktop with a knife.
Posted : 17/09/2021 5:27 pm
You looked but didn’t see 😉
😂 silly me, in my defense I've never heard of a bread knife that requires neither a video to explain its use, nor a second knife for left handers 😉
Posted : 17/09/2021 5:36 pm
My GF is somehow able to teleport the far-endy-bit out of the bag without disturbing any of the other slices. Especially if she suspects its a particularly thick one.
Posted : 17/09/2021 5:48 pm
 grum
Yes we get it gauss 1777 you're very good at cutting bread, and can easily and perfectly cut any bread with any bread knife, and anyone that can't is pathetic.
Posted : 17/09/2021 5:50 pm
I think since the word etiquette is in the title it is worth pointing out that etiquette dictates the only possible use for sliced bread is to enclose fried goods such as bacon, sausage, egg, etc. or possibly for fried bread.
Posted : 17/09/2021 7:02 pm
See also cheese, cakes, cheesecakes.....🤦‍♂️
To be fair MrsMC is disabled and only has one properly working hand. And refuses to ever ask for assistance.
Posted : 17/09/2021 7:10 pm
Yes we get it gauss 1777 you’re very good at cutting bread, and can easily and perfectly cut any bread with any bread knife, and anyone that can’t is pathetic.
Apologies if I got the tone wrong, I did not intend to offend anyone.
Posted : 17/09/2021 9:11 pm
@grum I've been using one of those for the past ten years.
My outlaws bought it for us. They didn't factor in that they are left or right handed and got us a left-handed one. Great for me, useless for my wife. It's really good. The only drawbacks are struggling areally bit with super tough bread and cutting the very last part of the slice.
Posted : 17/09/2021 11:32 pm
Can't you just use a hack saw and swivel the blade 90 degrees to which ever side you require!?
Posted : 17/09/2021 11:38 pm
This knife has cut all kinds of bread for us over >20 years. https://globalknives.uk/gu-03-bread-knife-22-cm
Posted : 17/09/2021 11:57 pm
 grum
Cheers @reeksy - the last bit of crust is always the tricky part! The curved blades like on the Opinel bread knife does help with that, but my missus' main problem seems to be cutting straight slices and I think the fiddle style one might help with that.
No worries. Hard to judge tone online, apologies if I misjudged you as being snarky!
Posted : 17/09/2021 11:59 pm
So..we have grum's bread saw and artisinal spelt or sourdough bread.
Next - hand churned butter from
lovingly tended cows grazed on the farmland around the manor house.
Toasting fork, hand wrought to your design by local blacksmith; well seasoned cedar logs burning in the open fire.
Slice bread, have man servant affix to toasting fork and allow 45 seconds per side at distance of 12" from flames; generous application of butter and...enjoy!
Posted : 18/09/2021 12:48 am
 grum
I do have some raw cultured butter in my fridge actually (to go on my organic heritage wheat sourdough).
https://fenfarmdairy.co.uk/raw-butter/
Have to work on the rest of it though.
Posted : 18/09/2021 12:59 am
They didn’t factor in that they are left or right handed and got us a left-handed one.
If its screwed in can you not just unscrew it and flip it over ?
Left,becomes right.
Posted : 18/09/2021 4:08 am
Absolutely, I could, but I'm left handed.
Posted : 18/09/2021 1:08 pm
I do have some raw cultured butter in my fridge...
Butter in the fridge?! 😱 For the love of dog, how do you spread it?
Posted : 18/09/2021 4:38 pm
Eat everything starting with crusty end then keep the rest in the fridge.
Posted : 18/09/2021 6:03 pm
Bread in the fridge?
Proof absolutely that Chewkw is a troll.
As to the bread and butter discussion. Whether artisan sourdough, or white sliced. Hand churned un pasteurised or utterly butterly, it matters not a jot, since Nigella.
Butter, then a bit more butter, and then a grind of salt from our salt grinder and your toast and butter is elevated beyond.
Of course my BP is 200/120, but it tastes so good!
Posted : 18/09/2021 6:19 pm
I open the bag, start at that end and work through until I get to the other end. Like any sensible person would do.
Posted : 18/09/2021 8:32 pm
 grum
I haven't started it yet.
Posted : 18/09/2021 10:01 pm
Tiger bread? no thanks. What actually is it? I just don't get it. Supermarket bread with sesame oil or something?
Posted : 18/09/2021 11:15 pm
