Sleeve Anchors - ho...
[Closed] Sleeve Anchors - how strong are they?
So I'm putting together a smallish desk that's going to be a piece of timber 1200 x 600 set on two heavy duty shelf brackets. To fix the brackets to the wall, I've got three sleeve anchors per bracket, M8 x 50mm.
I'm starting to wonder if the anchors are big / strong enough - I have never used them before so don't know the recommended depths / sizes. Have I got the estimate horribly wrong or will it all go to plan?
By the way, I could easily go and get different fittings if I'm totally in the wrong ballpark...
Posted : 20/02/2015 5:08 pm
Depends what you're putting on the desk I guess but wall anchors are solid. Well as solid as the wall you're inserting them into.
Are they going directly into brick/block?
Posted : 20/02/2015 5:16 pm
The sleeve anchors will not break. Tell me more about the wall which is going to hold them, and imagine two people sitting on the edge of the desk.
Posted : 20/02/2015 5:17 pm
er... it's an external cavity wall... is that enough?! Hopefully nobody will ever sit on it...
Posted : 20/02/2015 5:22 pm
If it's brick or block, I wouldn't use sleeve anchors - I'd prefer a coach screw and plug
Posted : 20/02/2015 5:27 pm
jota - interesting, what sizes would you suggest? Are you saying that due to risk of the brick/block not being strong enough to take the anchors?
Posted : 20/02/2015 5:29 pm
Sleeve anchors are mainly use in solid material like concrete, anything that could have things like frogs can stop a sleeve getting purchase.
EDIT 6mm, I think - needs a 10mm drill and a 13mm socket to put them in
EDIT, EDIT, just been to look, what I use is Hilti HUD in 8x60 for brickwork
https://www.hilti.co.uk/anchor-systems/plastic-anchors/r637
Posted : 20/02/2015 5:31 pm
Thanks, I may try to pick up some coach screws and plugs instead then. Sorry for being dim, but when you say you use the 8x60 plugs, what size screws and you are talking about to go with them? No such thing as a stupid question, right? ๐Ÿ™‚
Posted : 20/02/2015 5:56 pm
Plugs will be 10mm - 10x50 or 60 or 80
The screws will be 8mm, length is plug length + bracket thickness
Posted : 20/02/2015 6:02 pm
Thanks buddy - much appreciated.
Posted : 20/02/2015 6:03 pm
This should give you a better idea
You could get away with smaller ones but without seeing the desk, it's hard to tell.
Posted : 20/02/2015 6:08 pm
All good, plugs and screws bought. Ready for action. Cheers again.
Posted : 20/02/2015 6:22 pm
jota - thanks again, full success ๐Ÿ™‚
[url= https://farm9.staticflickr.com/8625/16620785791_f9dd0821d8_b.jp g" target="_blank">https://farm9.staticflickr.com/8625/16620785791_f9dd0821d8_b.jp g"/> [/img][/url][url= https://flic.kr/p/rjHSyg ]Wall mounted desk[/url] by [url= https://www.flickr.com/people/29308693@N04/ ]theflatboy[/url], on Flickr
mlc - I did sit on it, and so far it is rock solid!
Posted : 23/02/2015 10:24 am
