Skype for MacOS X 1...
[Closed] Skype for MacOS X 10.6.8?
3 Users
Have had an older Mac (running MacOS x 10.6.8) for a few years and recently Skype stopped working, you seem to need the latest version to get access, which wont run on anything older than MacOS X 10.9.
I've tried a few older versions of Skype available online (Skype 6.15), but no luck. Other versions are 'unable to connect'. Any ideas? Or should I resign myself to Skype-ing on the tiny phone screen for now?
Cheers!
Posted : 10/09/2017 1:27 pm
you can edit the OS to report a different version so the application will attempt to run.
http://justindaigle.com/blog/2010/02/tutorial-change-mac-os-x-system-version/
you can also edit the resources in the app/contents to the same effect changing the text which specifies a minimum version this is probably a sefer way to do it
neither will work if the app reies on components that are only in the later OS but in my experience it usually works
Posted : 10/09/2017 1:37 pm
Upgrade the Mac OSX ? My 2009 Mini I always kept up to date, Sierra was forst OSX it would not take. You will need 4gb ram min mind for anything recent
Posted : 10/09/2017 2:38 pm
