I've been putting off making or buying my son some shelves for his bedroom and need some inspiration. Ideally they'd need to fit up against the slope of the roof to the left as it's a loft conversion. I'd like to keep it simple, but feel free to show off your works of art.
no photos, but all my shelves are scaff planks from the local wood recycling place. If you're cack-handed (i.e. me), they'll cut them to size and sand them for you. Look nice, simple to do, cheap.
However, the thought of a sloping wall on one side is already giving me cold sweats
It's a bit wonky!My lad's first snowboard and a couple of clamp style brackets
๐
I like that!
No fine art here, but I'm proud of them because they actually came out looking surprisingly like my sketched plans (which is a first for me):
In terms of mounting I just used architrave mouldings ([url= http://www.diy.com/departments/softwood-mouldings-smooth-architrave-t15mm-w58mm-l2100mm-pack-of-1/1168969_BQ.prd?TI_C_DE_D_IL ]this sort of thing[/url]) as batons on the wall then laid the shelf on top with a couple of screws through it to make sure it didn't slip about.
lovely job muppetwrangler, very neat!
how are they for support on the angled side? The underside of my stairs seems to be some fairly lightweight board - not sure I'd want to put much weight on there...
Same way on both the square and the angled side. This isn't my picture but the underside looks a bit like this. I think I used 4 screws on each side.
The pocket holes are drilled using one of these
Really was a very easy way to do it.
Regarding the lightweight board. I probably had a bit of an advantage as I rebuilt the whole under stair area so I was able to strengthen that area prior to adding the shelves. It was a long time ago now but i think the shelves are fixed to 12mm mdf.
ooh, that's quite nice! So presumably your rawlplugs go in at a bit of an angle too? Is it tricky to get them to line up?
Because i was going into wood (well mdf) on both sides I didn't need to use rawlplugs. Not sure that i would use the same method if i was going in to brick or block. In theory it sounds possible but in my head it seems to go from really easy to a bit fiddly as soon as you add in the complication of masonry bits and plugs.
Nice lamb banana
