Shhh keep it quiet:...
[Closed] Shhh keep it quiet: my iMac has failed
15 Users
Don't tell the pc users, but my 2year old iMac has a problem.
It boots up. I log on. Safari fires up as per settings.
Then **** all. Mouse moves, icons on the doc act when hovered over, but Clicky no worky.
I can't even force quit safari or restart finder.
Any ideas??
Posted : 15/02/2011 7:01 pm
Check across the top by the vents - is it a bit hot?
Sounds like it might be firing up, HDD getting a bit hot and then everything grinding to a halt...if it's getting hot, then stop, don't do anything, and get a specialist to recover your stuff.
Posted : 15/02/2011 7:04 pm
Don't fire up Safari? Trash it and download a new version?
 mrmo
get the boot disk and launch from that, see what happens,
If you have the original disks there should be a diagnostics disk in there, but expect your fans to go like mad.
I had an issue a few years ago with some new memory causing the system to crash, but only after it got a little warm.
Posted : 15/02/2011 7:07 pm
Mouse problem? Just a thought.
Posted : 15/02/2011 7:21 pm
Could be worse, your Immac could have failed.
Posted : 15/02/2011 7:22 pm
Do any of the keyboard shortcuts work?
Posted : 15/02/2011 7:28 pm
+1, use Firefox instead.
Posted : 15/02/2011 7:30 pm
my iRON failed the other day so all my shirts have been creased this week
Posted : 15/02/2011 7:54 pm
it aint getting hot. it's not up and running for that long.
I'll fish out the disks and try them.
cheers!
Posted : 15/02/2011 7:55 pm
Try a different keyboard or at least unplugging and plugging it back into a different USB port?
Posted : 15/02/2011 8:04 pm
if you hold in shift as it starts up it'll start it up in a safe mode, might disable your startup items, i'm guessing that's why safari is launching, then that'll tell you if it's safari that's causing the problems.. dunno just a guess.
Posted : 15/02/2011 10:13 pm
also if it's a disc problem.
if you hold in apple+S as you start up that'll get you into single user mode(command line thingy like dos) and you can then check if there are any problems with the disc.. type in fsck -yf wait till in finishes then restart it(type exit or reboot, canny mind.)... like i say just guessing.
Posted : 15/02/2011 10:15 pm
applejack it.
Posted : 15/02/2011 10:35 pm
Repair permissions from startup disc
Posted : 15/02/2011 10:38 pm
CRTL ALT DEL?
Posted : 15/02/2011 10:43 pm
It was a wireless mouse problem: mac OS reputation remains intact, PHEW!
Posted : 18/02/2011 7:44 am
