Sheffield brazing r...
Sheffield brazing repair
I have a small shaft that needs building up where it has worn under an oil seal and seized bearing. 20mm dia shaft and about 15mm length needs building up by about 1mm. I can machine it back. Anyone know anyone in Sheffield who could do this?
Cheers!
Posted : 12/01/2024 7:33 pm
https://www.skf.com/uk/products/industrial-seals/power-transmission-seals/wear-sleeves/skf-speedi-sleeve
ive used these previously with good results
Posted : 12/01/2024 9:42 pm
I used to get a lot of emails offering that kind of result.....
Posted : 12/01/2024 10:18 pm
tillydog, geck0, tillydog and 1 people reacted
Is brass going to be durable enough? For crankshaft repair, usually it’s a weld and re grind job - so maybe some sort of automotive specialist?
Posted : 13/01/2024 11:51 am
I do a bit of brazing & have a workshop up off Norfolk Park, drop me a line and I'll see what I can do.
Posted : 13/01/2024 1:33 pm
I used to get a lot of emails offering that kind of result…..
Used to? So it works then?
Posted : 13/01/2024 4:48 pm
Cheers all, and thanks for the offer podge. I knocked up a brass sleeve on the lathe so will see how that fares for now. The shaft is from a pillar drill so it's not going to be seeing masses of use, and a slow oil leak will just lubricate the quill...
Posted : 13/01/2024 9:05 pm
