Shed window advice
[Closed] Shed window advice
So i started building our shed at the weekend. Considering i have no real DIY skills or power tools (got a drill) it started ok.
So im now at the stage where im putting the walls / windows in. Id like to get as much light in there as possible but im a little worried that its going to make it all too easy for people to break in.
So any suggestions as to what to do window wise? Or do i just pop some basic ones in and stop worrying about it?
Posted : 27/10/2014 12:52 pm
Ebay - nearest, cheapest, internally glazed double glazing unit you can find 😉
Posted : 27/10/2014 1:02 pm
cheap double glazed unit from Ebay- I paid about £50 for a smallish unit which was brand-new (ex showroom model - I picked it up from their works) it came with a key + fitting hardware (some random brackets that I didn't use)
I bolted a couple of those punched metal bars you can buy from Screwfix (builders use them) inside the window as 'security' bars.
It isn't perfect - but it'll do.
Posted : 27/10/2014 1:13 pm
get some wire mesh and nail/screw it onto the inside over the window. Also buy some film to make the windows opaque, so nobody can see in.
Posted : 27/10/2014 1:15 pm
Bullet proof glass is what you want 😉
Posted : 27/10/2014 1:21 pm
I used [url= http://www.wickes.co.uk/Products/Building-Materials/Roofing/Polycarbonate-Sheets+Trims/c/1000251 ]polycarbonate sheeting[/url] for my roof. Thus far, it's ace - heaps of light and heaps of wall space as there's no need for windows!
I used opaque ones. You could put a galvanised rebar grill underneath it for security underneath them if you wanted?
If you want pics just say - I'm thrilled with it!
Posted : 27/10/2014 1:23 pm
yea that was my first thought but the only ones that seem to be affordable are white upvc or knackered or to far away
Posted : 27/10/2014 1:24 pm
I recently made a new window for the shed using 3x3 and 2x2 which had 1" routed off it. I then glued and screwed it and fixed it in place with expanding foam. It doesn't open but its a good solid window and didnt cost much at all. For security, i have a steel gate bolted to the inside wall behind the window and two of those blinds in a box from wilkos.
Posted : 27/10/2014 1:33 pm
Where can you get that wire mesh mentioned?
Posted : 27/10/2014 9:54 pm
Georgian wire glass. Screw the beads internally and make them hefty. Or a piece of 6mm laminated glass, you have to literally hack your way through it.
Posted : 27/10/2014 10:16 pm
